A-basin photos
16 replies to this topic
#1 liftmech
Posted 09 March 2005 - 07:36 AM
Norway, a 1979 Yan double.
Bottom terminal.Attached File  bottom_Norway.jpg (132.98K)
Top terminal.Attached File  top_Norway.jpg (127.26K)
A unique Yan combo assembly.Attached File  spare_tyre.jpg (84.35K)
Detail of Yan pneumatic tension.Attached File  detail_Yan_pneumatic_tension.jpg (167.19K)
#2 liftmech
Posted 09 March 2005 - 07:42 AM
Lenawee Mountain, a 2002 Poma triple
Bottom terminalAttached File  bottom_Lenawee.jpg (159.12K)
A 2-4-2 assemblyAttached File  2_4_2.jpg (226.55K)
Top terminalAttached File  top_Lenawee.jpg (121.92K)
The carriers are standard Poma Omega triples; nothing special here.
#3 Duck
    Mechanical Designer
  • 391 Posts:
Posted 09 March 2005 - 09:36 AM
Pneumatic tensioning? Do you mean hydraulic?
Most cylinder-based tensioning systems I've seen are hydraulic with a nitrogen accumulator.
-Iain
#4 highspeedquad
    Fixed grip hater, L-P lover.
  • 764 Posts:
Posted 09 March 2005 - 01:35 PM
So the Norway Yan is height adjustable. That seems to be somewhat common among Yans of the same design.
It could be pneumatics, but I know hydraulics to be more common in lift tensioning systems.
This post has been edited by highspeedquad: 09 March 2005 - 01:36 PM
#5 Boeinglover
    Near expert skier + computer geek.
  • 164 Posts:
  • Interests:I like airplanes, skilifts, boats, computers, and skiing. Thanks for reading my profile! <br />P.S. Long live the greeks! :)
Posted 09 March 2005 - 03:24 PM
It's been bugging me lately because I really want to find out if the Lenawee Mountain has footrests :censored: . I also am curious to find out more about the Pallavicini lift (as I've only ridden on it once).
To be or not to be, that is the question of life.
by William Shakespeare, and not me
I am lucky! I won the heads and tails game 300 consecutive times! You see the rules are: heads I win, tails you lose
#6 poloxskier
Posted 09 March 2005 - 05:32 PM
Norway, Exhibition, and moly hogan are all height adjustable.
Yes it has footrests.
#7 Kelly
  • 2,913 Posts:
Posted 09 March 2005 - 07:45 PM
-Pneumatic
-Bottled nitrogen
This design profile has very little active carriage travel.
Often this style of lift is run with the chain dog bottomed to save on nitrogen.
Chain dog is hidden in 90 degree turn of the chain.
Also-
Pure Nitrogen will displace Oxygen, quite lethal if you breathe it for any length of time.
Nitrogen should not be confused with nitrous oxide the gas your dentist uses.
More info -
http://www.skilifts....?showtopic=2166
Ryan B
#8 liftmech
Posted 10 March 2005 - 04:35 AM
Palvicini, also a 1979 Yan.
Bottom terminal, very similar to Norway.Attached File  bottom_Pali.jpg (128.76K)
Tower 7.Attached File  T_7_Pali.jpg (111.62K)
Top terminal.Attached File  top_Palivicini__1.jpg (97.1K)
I believe there are five towers on this lift which only support the heavy side; very even profile for a lift.
#9 liftmech
Posted 10 March 2005 - 04:45 AM
Exhibition. This is the fourth or fifth lift to use this line; there are at least two different types of towerbases visible when the snow melts.
#10 liftmech
Posted 10 March 2005 - 04:48 AM
Molly Hogan.
#11 highspeedquad
  • 764 Posts:
Posted 10 March 2005 - 06:01 AM
What different kinds of lifts were there along the line of Exhibition?
#12 poloxskier
Posted 10 March 2005 - 08:33 AM
The original single chair was there an I belive a t-bar and a poma. At least one of the surface lifts was there at the same time as the single chair.
#13 SkiBachelor
Posted 10 March 2005 - 09:36 AM
Actually when Brad and I were there this summer, we went into the lodge and looked at some of the old pictures from the area. It appears that there were two Miner-Denver lifts that run up the same lift line at Exhibition.
#14 poloxskier
Posted 10 March 2005 - 10:06 AM
Oh ok, where did the single run then?
Or was the single replaced by the miner-denvers?
This post has been edited by poloxskier: 10 March 2005 - 10:07 AM
#15 SkiBachelor
Posted 10 March 2005 - 10:31 AM
The Miner-Denver's probably replaced the single and POMA.
#16 Zage
  • 358 Posts:
Posted 10 March 2005 - 11:24 AM
Hmmmm, a tyre on the sheave assembly, interesting. The paradise triple at Lake Louise has that same thing.
Tyler.M
#17 liftmech
Posted 12 March 2005 - 04:48 AM
It's a Yan thing. Old B-1 had one, as do chairs 1 and 2 at Loveland.
At one point the Basin had two parallel Poma platters along the Exhibition line; one was replaced by the single.
