lastchair_44, on Oct 14 2007, 08:22 AM, said:
....I thought I did???? Really though, the clamp broke as I was finishing the cut on this section of track rope. It looks like it's happened to the swiss guys a couple times as well so I dont' feel that bad. I was pretty much all the way through with the exception of the outter "Z" wires. Going back to try again today. (Kinda crappy picture due to cell phone cam)
There is, or was a video of the track cable from the Vail Lionshead Gondola being cut as it lays on the ground. (Dead rope, not under any tension.) This is the track cable involved in the incident in 1975/76. They were using a cut off wheel. The z-locked cable was clamped and tied down to concrete blocks on both sides of the cut. At the last nip through the z-lock the thing took off and blasted the clamps off. The concrete blocks spun out with the unraveling rope. The surrounding ground was dug up etc. Fortunately the the guy cutting was on the "right" side of the rope so it spun away from him. Interesting.
Also, as the guy started to cut the rope he had the cut off wheel sparks shooting on his pant leg. About half way through, you see his hand come down to beat out the flames below his knee!
