Now you might think that this is the bottom station and yes the top most likely was flat but the drive is not the same as other 'cakes built soon after. The drive is a square and isn’t even sloped at all like the drives seen on the ones at Sierra, Whistler and other places. You can also see that the operator boxes are the older style simple ones, not the more modern ones seen their other lifts, even J7 an 88 Yan quad.
-The top terminal:
-J7's operator boxes:
The next odd thing on this lift is the carriers. These are oddly shaped even for yan teardrop style chairs. Today I looked at some pictures of other Yan hsq's at Sun Valley and even mammoth. They all have chairs that are more rounded and not at all similar to J6's.
The last odd part about this lift is the towers. These Yan towers are thicker than any others I have seen, including 5 other Yan express lifts (2 being the towers on Grandview and West Bowl at Sierra which re-used the towers when they replaced their yan express quads). They also have interesting lifting frames, again thicker and stronger looking than the "Y" looking ones on J7 and others. J7 does have two towers with these frames but they are only the breakovers at the top of the lift.
-Tower construction different as well, not bolted on but actually welded together:
I will try to email June/Mammoth and find out what I can unless someone on this forum has more info. It would not surprise me at all if this were the first because June was also the testing ground for the QMC so this could be another instance of testing a new potential product. I know Mammoth and Lift Engineering were very close from Yan's start to the mid 90's and June would be a good place to prototype something like this since it sees less people than Mammoth.
