The brakes serve several purposes:
To decelerate (stop) the ropeway in the event that electrical braking does not provide sufficient deceleration; initiated if one of the "Service Stop" or "Emergency Stop" buttons is pressed, or if a control device is tripped.
To hold the ropeway at a standstill (during breaks in operation or shutdowns).
To regulate rope speed when clearing the line using an overhauling load (manoeuvring).
The braking force is transmitted to the haul rope via the bullwheel. As far as the transmittable braking force is concerned, the same physical principles apply as those already described for the transmittable driving force.
Circulating monocable ropeways are equipped with two brakes (service brake and emergency brake) which are connected to separate control circuits.
Once activated, these brakes are automatically engaged and apply the same braking force in both directions of rotation. Both brakes operate according to the "normally closed" principle.
