Changing Lift Capacity
Posted 23 February 2005 - 03:02 PM
Posted 23 February 2005 - 03:09 PM
Posted 23 February 2005 - 03:14 PM
Also, if both the intervals were 6 seconds, why would one lift have more and the other have less capacity? It doesn't make sense. Does it have to do with the spacing on the line and the speed?
This post has been edited by highspeedquad: 23 February 2005 - 03:16 PM
Posted 23 February 2005 - 03:29 PM
Posted 23 February 2005 - 03:37 PM
What about fixed grips? Are you stuck at the design capacity no matter what?
Posted 23 February 2005 - 03:46 PM
Posted 23 February 2005 - 03:50 PM
Posted 24 February 2005 - 05:22 AM
Loading interval is directly related to line speed. A fixed-grip operating at 500 FPM and with 50' chair spacing will have a six-second load interval. A detachable running at 1000 FPM and with 100' spacing will also have a six-second load interval. If you have a five-second interval, then you end up moving every chair forward 16.667 feet. That would allow you to add 44 carriers on a lift the size of the Flyer, which has 203 carriers.
Posted 24 February 2005 - 05:54 AM
Time the interval between chairs. To get a higher capacity your interval has to be less. You can decrease that interval by a ) adding chairs or b ) speeding up the rope.
Ultimately the defining factor on capacity is interval and capacity per carrier.
This is why a compact coaster running all 3 trains on a busy day, at 12 passengers per train, can have the same capacity as say, a big B+M hyper running just 1 train on a slow day, that holds 36 passengers.
(and all the B+M hypers have 3, 36 passenger trains. ;))
A fixed grip chairlift can have the exact same capacity as a detachable, if the time interval between chairs is the same. Assuming the rope speed is significantly faster on the detachable, though, the spacing (pitch) on the ropeway would be greater. But of course the travel time to the top will be much reduced on the detachable because of the higher rope speed.
-Iain
This post has been edited by Duck: 24 February 2005 - 05:55 AM
#13
Posted 24 February 2005 - 06:24 AM
#14
Posted 25 February 2005 - 04:53 AM
I did say that the Flyer is not running at final capacity, but we're not going to take it to that point because it would never run well with 44 extra carriers. There are enough beginners crashing and burning on the ramp as it is
Posted 27 February 2005 - 12:25 PM
Number of downloads: 23 -
Number of downloads: 26 -
Number of downloads: 19 -
Posted 27 February 2005 - 03:03 PM
#17
Posted 27 February 2005 - 03:33 PM
Posted 27 February 2005 - 07:48 PM
Posted 27 February 2005 - 08:06 PM
