Mt. Bachelor Pictures
59 replies to this topic
#41 SkiBachelor
Posted 15 December 2003 - 10:07 PM
The top terminal. I didn't want to take another picture of inside because I felt like I mgiht get in trouble. Maybe later when I have clearance. B)
#42 KZ
    Multipurpose Machine
  • 2,087 Posts:
Posted 16 December 2003 - 06:53 AM
nice rime
Zack
#43 liftmech
Posted 18 December 2003 - 12:48 PM
That lift gets a great deal of rime- every time I've been there it looks exactly like that. The crew that opens up the lift after a day or so of downtime has to knock off quite a bit of it to run the lift. I've heard of 'ice tunnels' around the sheaves and rope on the towers; only the moving parts are warm enough to stay ice-free. Thus the necessity for the night drive...
#44 floridaskier
Posted 02 January 2004 - 03:12 PM
Inside the Summit Express terminal buildings, do they have real snow or some fake stuff for the loading ramps?
#45 SkiBachelor
Posted 02 January 2004 - 06:29 PM
Rubber mat type thing.
#46 KZ
  • 2,087 Posts:
Posted 02 January 2004 - 11:48 PM
they had some carpet at the bottom of eagle express (the uni-g) at mamomth due to lack of snow. It was a bit stickey
Zack
#47 floridaskier
Posted 04 January 2004 - 09:46 AM
Sometimes they have carpet or AstroSnow or whatever else you want to call it at the bottom of PCMR's Town lift (85 CTEC FGT) that starts on Park City's Main Street. It's really weird under your skis
#48 liftmech
Posted 07 January 2004 - 07:50 PM
We are :offtopic: but anyway- I've put down treated plywood an inch lower than ramp height, and then bolted inch-square bars of UHMW plastic down every foot or so. That provides a smooth surface, and also holds the snow in place.
#49 CAski
  • 363 Posts:
Posted 13 January 2004 - 10:24 PM
Squaw just uses hay. I still had some stuck to my skis from Thanksgiving this Christmas.
#50 SkiBachelor
Posted 13 January 2004 - 10:28 PM
Mt. Bachelor uses that stuff too, although only at the start of the season. I have some pictures of this on the site if you look at the Mt. Bachelor pictures. :)
#51 floridaskier
Posted 16 January 2004 - 12:57 PM
DV hasnt got much of a problem with unloading ramp snow, and they don't use wooden ramps, all snow. It does get a little blown off though
#52 liftmech
Posted 13 May 2004 - 03:28 AM
Cameron, I'm going to tag a pic onto your thread here; it seemed an appropriate place.
The Yellow chair (seen in the middle between Pine Marten on the left and Red on the right) got removed, did it not?
#53 SkiBachelor
Posted 13 May 2004 - 07:17 AM
Yes this lift was removed and only two towers remain of this lift along with the top station's lift shack. :(
#54 crazyskier91
  • 652 Posts:
Posted 24 May 2004 - 05:53 AM
Why is it resorts tend to leave stuff like operator shacks and unloading platforms?
Elevation 9,600 Feet
President
#55 liftmech
Posted 24 May 2004 - 07:05 AM
Most don't, actually. You'd be hard-pressed to find any evidence of the old lifts at Copper unless you hiked the lines. All that remains of them are the tower footings, whether it's the Heron bolt cage or a torched-off piece of tubular steel from the Yans. The only lift I've found a terminal footing from is old I-lift. Same with Crystal and Whistler. As to why some resorts do leave things, my theory (having torn out a lift before) is that they ran out of time.
#56 SkiBachelor
Posted 24 May 2004 - 07:45 AM
The line equipement that remains from the yellow chair is actually used. The top lift shack is used for NASTAR while the bottom tower has a Borer tube tow attached to it.
#57 Dr Frankenstein
    C.S.I.A. Level 1
  • 436 Posts:
  • Interests:Computers, skiing
Posted 24 May 2004 - 08:38 AM
Mont St-Sauveur leaves many things whan they remove chairlifts. We still can see:
-The bottom terminal of the côte 69 double
-The unloading platform of the same lift
-Almost all the towers of the côte 71 T-Bar
-etc.
#58 crazyskier91
  • 652 Posts:
Posted 24 May 2004 - 09:23 AM
You mean hiking the lines and looking for things, and what is a Heron bolt cage?
President
#59 liftmech
Posted 26 May 2004 - 04:04 AM
I mean hiking the old liftline.
A Heron bolt cage is the bolts embedded in concrete that held the tower to the footing. Yan and Riblet were direct burial- the tower was placed in the hole, aligned using three small hand winches, and then concrete was poured around it. Riblet had a sleeve which was place in the hole before concrete was poured, and then once the footing set up, the tower was place in the sleeve and welded. Later they placed a piece of pipe with half of a bolted flage welded on top; the matching half was welded to the bottom of a tower. Most other manufacturers have some variation on the bolt cage. Now that we're :offtopic:
#60 floridaskier
Posted 26 May 2004 - 12:34 PM
The Canyons has the bottom tension support for the old Raptor FGQ- a CTEC moved to Dreamscape that ran next to Golden Eagle- on the runout down to Golden Eagle. I dont know if it's still there, I didn't go down there this year.
