Lift drive trains
Posted 11 December 2004 - 04:53 AM
Has anybody seen any other type of lift drive trains, aside from the vault and shaft method or the more modern overhead drive?
Posted 11 December 2004 - 05:02 AM
Posted 11 December 2004 - 05:43 PM
Posted 12 December 2004 - 05:00 AM
Posted 27 December 2004 - 10:25 PM
A homebuilt t-bar with a wormgear drive, powered by a Ford 460 with a direct taper fit and adapter collar to the gearbox...I seen that...don't quite remember where...my dad had a picture though...
A mueller t-bar with a silent chain (like a HYVO snowmobile chain)
direct to a 90 degree. The chain ran inside a sealed gear case. Also, just like a snowmobile... I believe it was a mod from the original belt drive.
A roebling t-bar at Mt. Whittier NH, looks like a willys Tornado Inline Flathead 6 to a 3 speed manual then to a dana 20 transfer case and an output shaft to a 90 degree. Oddly enough a factory setup for no e-motor.
Posted 28 December 2004 - 05:59 PM
poloxskier, on Dec 12 2004, 06:00 AM, said:
Strictly electric. There is no need for a backup engine- just release the stick and ski away in the event of a power failure
Posted 29 December 2004 - 01:22 AM
Posted 29 December 2004 - 12:16 PM
Allan, on Dec 28 2004, 12:05 PM, said:
ha ha ha.. good old ford 300....4.9l right? I can see it now...chairlift drag racing... :help:
Posted 23 February 2005 - 10:27 PM
Posted 24 February 2005 - 04:58 AM
Posted 24 February 2005 - 10:19 AM
Posted 01 April 2005 - 01:19 PM
Posted 25 April 2005 - 06:15 PM
Another arrangement I've seen in ancient Poma doubles has two motors: one motor is inline-shaft coupled to a right angle speed reducer (which looks like it belongs on a Poma surface lift), which drives the bullwheel through a spur-gear/bullgear arrangement (like the old Hall's). There is a second motor mounted below the main driveline in parallel, with a V-belt coupling it to the main driveshaft (I've seen this twice - both lifts are long gone). Does anybody have any explanation of this? Does one of the motors act in place of the resistor pack (wound rotor again)? The whole arrangement is very magnetically noisy until it reaches running speed.
Posted 28 April 2005 - 05:08 AM
Matt, on Apr 1 2005, 02:19 PM, said:
Probably because the main gen set can't keep up with the demand of powering an additional motor. Baker is 30km from the grid and all lifts are diesel-powered save the handle tow. Chair 1, as well as old chair 2, had their backup engines coupled to the high-speed shaft via a very long chain. No fun, and very noisy.
#19
Posted 28 April 2005 - 03:51 PM
