What Hsq Or HSS has the steepest
16 replies to this topic
#1 Kicking Horse
Posted 02 August 2004 - 03:32 PM
What Hsq or HSS has the Steepest Climb?
Must be in the usa.
#2 SkiBachelor
Posted 02 August 2004 - 04:25 PM
What kind of question is this Jeff, because there can be more than one answer for these questions?
For example, I would say the the Summit Express at Keystone has the most vertical, but then again it's a long lift. Then there is the Summit Express at Mt. Bachelor that has is a decent length but a very impressive vertical rise.
For the six-pack, I would say the six-shooter at Moonlight Basin, MT. It's a really long lift and has an impressive vertical because of it.
So you see Jeff, there is more than one answer for this question. If you want to know what lift has the most vertical, just look at the Lift Construction Survey's for this type of info.
#3 snowboardguy
  • 180 Posts:
  • Interests:SNOW
Posted 02 August 2004 - 04:44 PM
I think he means which lift goes up the steepest hill
#4 Kicking Horse
Posted 02 August 2004 - 05:07 PM
steepest climb out from Bottom Termainal....
#5 CAski
  • 363 Posts:
Posted 02 August 2004 - 05:45 PM
KT-22 Express has to be pretty far up there.
#6 KZ
    Multipurpose Machine
  • 2,087 Posts:
Posted 02 August 2004 - 06:39 PM
Its not too steep out of the terminal, but about halfway up when it goes over the cliffs its pretty good. Grandview is actually a little steeper then that in its speet section. Out of the terminal, I'm guessing Gunbarrel or maybe Mott Canyon at Heavenly are the best there, but Mott is a double so it does't count. I think the question should be what hsq/hss has the steepest section on the line.
Zack
#7 Kicking Horse
Posted 02 August 2004 - 07:39 PM
#8 KZ
  • 2,087 Posts:
Posted 02 August 2004 - 08:09 PM
Alright, I like that better. The steepest I think I've ridden is Grandview, final answer. I'm not sure how steep it is, but its pretty good.
Zack
#9 CAski
  • 363 Posts:
Mott actually has a bit of a flat stretch at the base.
It makes it kind of difficult to find the steepest lift when you are just looking at a certain section. It would be much easier to find the overall rise over run.
This post has been edited by CAski: 02 August 2004 - 08:13 PM
#10 liftmech
Posted 03 August 2004 - 04:00 AM
Rainier Express (Crystal) is probably the steepest detachable I've ridden, since we're not talking about gondolas. It's pretty flat in the bottom section, but steepens considerably past tower 10 up Sunnyside. Overall stats- 1750' vertical, 4400' length. That works out to a pretty steep lift.
#11 floridaskier
Posted 03 August 2004 - 09:48 AM
McConkey's HSS at PCMR has a very steep top section, but the bottom is nearly flat. DV's Empire lift has about the same profile, as they are very close to each other. The Canyons' 9990 Express probably has the longest really steep section that I've seen, if not that then Snowbird's Mineral Basin lift
#12 KZ
  • 2,087 Posts:
Posted 03 August 2004 - 10:49 AM
Chair J7 at June and Broadway at Mammoth both have some nice steep sections as well, I just forgot about them.
Zack
#13 Bill
    Founder
  • 2,851 Posts:
Posted 03 August 2004 - 11:02 AM
Liftmech would remember this one, the K2-Face part of the old C-5 at Crystal Mountain.
#14 ISMrider
  • 208 Posts:
Posted 08 August 2004 - 12:53 PM
Slide Brook on the Mt. Ellen side is steep. hmmmm if you did FGQ it would be the lift at Lake Compounce.
Ian
University Of Colorado at Boulder
#15 liftmech
Posted 11 August 2004 - 07:25 AM
Yup, that was probably the steepest fixed-grip I've ridden. It had two 12-sheave hold-down assemblies at the bottom, and four 8-sheave support towers at the top. K-2 Face itself was listed as a single diamond, but I think that was an oversight from before Crystal listed double diamonds as an official designation.
#16 snowboardguy
  • 180 Posts:
  • Interests:SNOW
Posted 11 August 2004 - 08:38 AM
I know this is on hsq's but the steepest fixed I've ridden in Chair 23 at mammoth
#17 floridaskier
Posted 11 August 2004 - 09:12 AM
Not really all that steep, but the Supreme lift at Alta has this one section where the downhill side skips 5 hold-down towers for the uphill side and goes really, really high over the ground
The Canyons 9990 lift has two 8-sheave hold-down towers at the bottom and 5 towers to get out of it (two halfway up with 6 each, 3 at top with 8)
