Is This a Hall Design, or Riblet?
Started by snoloco, Oct 21 2016 04:46 AM
7 replies to this topic
Posted 21 October 2016 - 04:46 AM
This is the top return on the Little Whiteface Double at Whiteface, NY. I've never seen it on any other Hall lift. That lift originally replaced a Riblet double, so I thought that it could've possibly been reused, but I haven't seen any other Riblets with that design either.
Posted 24 October 2016 - 03:51 PM
_litz, on 24 October 2016 - 02:27 PM, said:
Perhaps ... it still looks extremely solid, nonetheless.
There's pretty much no way to interpret that structure other than "boy does that look solid and strong"
While it is true that the top terminal needs to be solid and strong above ground, the below ground portion also needs to be substantial AND well attached to the underlying base rock. Others have found out (to their peril) in the last few years that some terminals and towers installed in the 80's and 90's were not bolted down quite as well as the owners might have liked (or suspected the day before the equipment fell over). One only needs to come see how much cement that gets buried for new ski lift tower footing installations where the entire hill is sand and gravel. very impressive.
