Who's still in winter ops? (open)
Posted 23 May 2016 - 04:14 PM
RibStaThiok, on 23 May 2016 - 03:09 PM, said:
Snowbird is still going. Look at the cams:
http://www.snowbird..../#mountain-cams
EDIT:
Forgot to mention, weekends only to the 29th.
This post has been edited by Smacpats: 23 May 2016 - 05:01 PM
Posted 23 May 2016 - 06:24 PM
This post has been edited by julestheshiba: 23 May 2016 - 06:25 PM
-Will
Posted 26 May 2016 - 03:52 PM
You Nearly can ski down to village!(note, at the time of when I posted this there still was tons of snow everywhere. Webcams update.
This post has been edited by Smacpats: 03 June 2016 - 12:58 PM
Posted 26 May 2016 - 08:07 PM
Posted 27 May 2016 - 06:18 AM
Backbowlsbilly, on 26 May 2016 - 08:07 PM, said:
If Telluride made a bit more snow they could still be in winter ops. I doubt Gold Hill or Palmyra would be skiable, but lift 6 would Absolutely be skiable. Lift 6 starts at the same elevation as the top of lift 10 (last webcam) and ends at the same elevation (Like 50 feet higher) as Plunge (3rd webcam)
http://www.telluride...tain/live-cams/
Telluride should find a way to do Summer skiing. One way is to keep Prospect running through June (it starts at about the same elevation as the last cam and ends at about the elevation of the third). The problem with that is that Prospect Basin is completely closed from May 20-June. Another idea is to do this map, (Normal red line = lift uploading only, Lift with arrows pointing up and down = Lift, uploading and downloading, Green line = Green trail, Blue line = Blue trail, Black line = Black/Double black trail. Everything to the right of the Big yellow line I drew would be closed during that 2 month period. The season could be finished up on Plunge and Apex, where the snow stays the longest (Facing the north).
If you are wondering why Gold Hill would have no runs under it, well, I don't think they could make this skiable in June.
This post has been edited by Smacpats: 27 May 2016 - 09:33 AM
#13
Posted 02 June 2016 - 12:16 PM
#14
Posted 02 June 2016 - 12:41 PM
