Pictures of River Run YAN Gondola
Posted 19 April 2016 - 01:02 AM
Anyone know how the grips worked on this? They don't look like the same ones that Yan used on the HSQs. Were they contracted from someone else?
Was the removal of this one mostly due to the Teller accident, or if not what other issues did it have?
Posted 19 April 2016 - 06:27 PM
There were VERY few of the original Swiss grips in service(maybe only one or two) and they were not adequate for a 6-passenger Gondola. So Yan scaled it up to hold a cabin using a single grip, which at the time was not allowed in Europe. Naturally, a single grip required a larger rope (due to shear ratio) so Keystone was stuck with a 55mm rope; and when Von Roll took out the Yan and put in the 1986 River Run, they elected to re-use the almost new larger rope, which of course required 500mm support sheaves. If they had a clean slate, it could have been built with a 48 mm rope, and in fact was changed to that with new grip jaws and rope when both parts needed replacing at some point years later.
Posted 19 April 2016 - 06:30 PM
2milehi, on 19 April 2016 - 08:35 AM, said:
If one motor breaks the whole thing is screwed
-Will
Posted 20 April 2016 - 03:17 PM
Posted 20 April 2016 - 03:55 PM
Most other clutchless spacing systems I've seen use 2-3 motors and require only the same number of belts added to have the contour powered by the PTO sheaves if the lift needs to be run without mains power.
Posted 21 April 2016 - 06:32 AM
Posted 21 April 2016 - 06:36 AM
As for power outages, I imagine there was genset back up....and in my 20 years at a Ski Area I remember 2 power outages....
- barnstormer likes this
- Like This
Posted 21 April 2016 - 06:45 AM
This post has been edited by 2milehi: 21 April 2016 - 06:46 AM
#18
Posted 21 April 2016 - 07:11 AM
- iceberg210 likes this
- Like This
#20
Posted 21 April 2016 - 11:42 AM
I really like the photos of what looks like an early Series 3 control system and Sabina 8800 drive.
This post has been edited by barnstormer: 21 April 2016 - 11:48 AM
