Cadence chains have problems in variable temperature conditions. It was explained in another thread ; I forget the title but they mentioned something about how chairs may come in late when it is colder out, and come in to early when it is hot out, (probably the other way around)
From what I understand, the big issue with carpets is loading speed vs. chair spacing. I heard that on the new Colorado lift that the carpet moves too fast relative to chair speed. I suppose that either you could space out chairs a bit more, slow down the carpet, or speed up the lift.
Personally, I think load carpets on detachables are rather unnecessary. The lift moves slow enough, even slower in cases like Ramshead or Barker, that people should have plenty of time to load. There are sometimes issues with misloads that we can't fix but for the most part detaches where I live are very well run by the lift operators.
One thing that I think would be neat but maybe not successful and possibly hard to implement would be unload carpets for lifts that held 6+ on a chair. I've heard that some six packs are just crazy when unloading, and I think a carpet would be neat since people don't really communicate on their plans very often. That said, I have yet to experience the true mess of a six besides Okemo. Ragged mountain (NH) has a 12 second interval on theirs, so theirs is fine (despite a fast unload like Excelerator at Copper, which I actually like because you don't need to push to get to some trails ;) ) Okemo's is a 2900 (Spaced about the same as Kensho) and had a lot of problems - never seen the source of any but I suspect it is the load gates or unloading on the 6. Sunday River's Chondola appears to be just fine, even if it serves the 2nd most beginner friendly terrain on the mountain, and I don't know what to compare the spacing to but the chair in front gets out of your way just in time.
I think an unload carpet would need a little tweaking for unload areas ; they're mostly elevated off the ground, so the carpet would need to be raised to match. Also, in the case like Ragged's Six, which unloads at a really fast speed, I think the transition would be impossible without falling (it is quite fast - you can see a video on my youtube channel from Jan 2015) so a carpet might be hard to add. However, I don't know about lifts like Colorado / uhh what is the new one at vail? Mountaintop? but if they ran slow enough at a constant speed it might be possible. Any insight on this? Seems like it might help but at the same time it might not.
By the way, I decided to be nice and not make you hunt for the video - see the unloading bit https://www.youtube....h?v=-vSC1Euev-k
This post has been edited by NHskier13: 08 April 2016 - 08:28 AM
