Lifts That Need Loading Carpets
Posted 05 April 2016 - 07:36 PM
-Will
Posted 05 April 2016 - 10:25 PM
Mike12164, on 05 April 2016 - 08:23 PM, said:
They do reduce misloads in my experience, but it does seem a little much, especially on high speed lifts.
Posted 06 April 2016 - 01:43 AM
I've only seen two so far (King Con at PCMR and chair 4 at Vail) but I'm really not convinced HS loading carpets are useful at all. Any lift with a lot of beginner skiers will stop all the time, whether you confuse them with carpets or not. The load gates on the old six packs at PCMR are confusing enough as is for the masses.
Posted 06 April 2016 - 08:42 AM
julestheshiba, on 06 April 2016 - 05:41 AM, said:
Then what is the best way to clear the crowds
"Proper maze design and better training for lift operators can and will accomplish the same thing basically for free."
Agreed. The best way is to have operators trained to ENGAGE the next group of skiers with direct conversation and instruct them each time as to what is going to happen. Standing by the side saying "How are you?" and "How was your run?" are something that was invented by the Marketing Department.
It needs to be "OK folks, you're next... follow this next chair out...OK make room for you partners...here's the chair...See YA" and repeat...all day long.
At least that's what I used to do back in the day and my partner and I could run a double in an intermediate part of the mountain all day WITHOUT a stop. That was our goal.
$0.04
Posted 06 April 2016 - 11:50 AM
Love this.
@julestheshiba, I think you may be a little misled but loading carpets don't really increase uphill cap significantly - it allows for faster lift operation which in theory would get a few hundred more people up the hill, however, in practice, it really is not effective as it causes a lot of slows and stops. A properly designed maze definitely helps. Oftentimes I see that sometimes the lifties just go on no craps given mode and let people through. There is then hiccups as just before the loading zone there are groups of 4... 5... 6 that still haven't split up. Another thing is loading area space. Sunapee did a great job of this on their new Sun Bowl express quad, which has a very spacious area to load and re organize before the loading zone and everything - certainly an improvement over the old quad which had wooden things to divide skiers, then funnel back into a skinny space. Oftentimes the dude on the outside would get shafted by a snowboarder and possibly be pushed off or sit on the handles of the chair. (No offense snowboarders ;) )
And lift operators - more experienced ones would always make a difference. Probably couldn't explain why without offending any new lift operators, and I couldn't do better so I will not go into that especially since I probably would sound totally like a fool
Posted 06 April 2016 - 12:53 PM
They run the Ramshead Express at 800 fpm while it's rated to run at 1,100. It doesn't seem to slow or stop much at that speed, but I sort of think it's too slow and that running at 900-950 would work better. I actually have trouble loading when the chair is going too slow as I'll move up too early and hit the chair in front of me. I wonder if it's possible to design a detachable lift with a lower terminal speed, while maintaining the same loading interval. Is it the speed or the loading interval that causes the most issues? I believe the Bluebird Express at Mount Snow has a slower terminal speed than the Kaatskill Flyer at Hunter, even though Bluebird runs faster and has a shorter loading interval.
If speed is the issue, than the best replacement for Ramshead (which often has the longest line on the mountain) would be a 6-pack with a 3,600 pph capacity, and a slow terminal speed that would allow it to run full design speed and have a greater capacity. I also am curious as to whether it is possible to do a modification to lower the terminal speed of a detachable lift.
Posted 06 April 2016 - 05:44 PM
Although I can't say I've experienced this in person, I think loading carpets on fixed grip lifts can increase the full design speed of the lift.
Posted 06 April 2016 - 06:59 PM
Posted 06 April 2016 - 07:08 PM
It's set up as 90 degree loading, so a replament lift set up the same way could have only the turnarounds at loading speed, giving a slightly lower speed.
90 degree loading is a problem on lifts with a fast terminal speed because there is only a very short time to load when the chair isn't turning. Hunter's Kaatskill Flyer has this problem. Fastest terminal speed of any detachable I've seen. The 6 pack chairs absolutely whip around the turns and if you don't load while the chair is straight, it can knock you over.
A replacement for Ramshead would need to use a longer terminal geared with a slower speed, but still a design speed of 1,100 to match the old lift. That and a well organized queue would help reduce stops and slows and allow the lift to run at or close to full design speed.
Posted 07 April 2016 - 07:25 AM
#18
Posted 07 April 2016 - 09:17 AM
vons, on 07 April 2016 - 07:25 AM, said:
this is squaws biggest problem
-Will
#19
Posted 08 April 2016 - 04:02 AM
julestheshiba, on 06 April 2016 - 05:54 PM, said:
How so? Cadence chains run at specific speeds to ensure proper spacing, and are not related to loading speed. In my experience they haven't been a problem.
My current crew has been more active in 'coaching' this season, and it's helped immensely.
