crazyskier91, on May 27 2004, 08:35 AM, said:
The guidage should be placed so that the carrier does not hit tower or sheaves before it strikes the halo. If you have an undesirable chair/tower interface. then the guidage is probably misadjusted. I've had to adjust Riblet halos before due to slippage over the years.
If you're referring to a Poma when you say the chair will hit the tower first, you're right. That's not guidage at all (highlighted in the photo) but a 'Pomapass'- their version of a maintenance catwalk.
