I heard this secondhand by someone in the lodge, but apparently they left the valley run ('97 doppy) and white peaks ('88 poma) running in the freezing rain so that they don't freeze up. I'm assuming that if they were doing that to prevent them freezing up, it's probably because of the grips or the sheaves on the towers. Something allowed them to not run white peaks by 1 in the morning, so they shut it down. Until 10 am, they were trying to get it up and running. The noticeable setback was the chair spacing - there was a chair, normally spaced behind another, then another three feet in front of that one, so they had to push the farther ahead chair through the terminal while the line was moving at very low speed to space the chairs out.
I had some videos of what they were doing, I can maybe get them up by tomorrow but until then, here are some photos of the chair spacing and them working to space them out.
EDIT : HERE IS THE VIDEO ; https://www.youtube....h?v=g0jaX3R66s4
Number of downloads: 184 Chair Spacing is On Point
Number of downloads: 231 This one is a bit fuzzy, but you can see some slack in the line. Is that because the chairs are close together?
So what exactly is the proper operation sequence when there is freezing rain overnight? Why were the chairs stored like that? What would happen if they weren't running?
This post has been edited by NHskier13: 02 January 2016 - 04:52 PM
