Ski Resort Imaging
#42
Posted 12 August 2004 - 12:49 PM
sorry this took so long, but I had other projects (work) to complete. Here is a winterized (plus lifts & runs) version. I don't like the pixelation seen in the map. For some reason this one just doesn't want to give me a higher resolution.
Powdr
#44
Posted 12 August 2004 - 02:34 PM
DID YOU KNOW, the original idea for Easy Gold was to have it dump out on Blowdown. New Cut was never intended to be a ski run, but it was cleared for the lift (which is why it was never given a real name). Because of limited funds they decided to make it shorter which is why the run New Cut ends right at the top of Easy Gold with nowhere to go.... They were going to make the lift with "2" unload stations (I guess enspired by the Dino) to unload in the current spot then continue up to Blowdown with an upper unload area. Good thing they changed their mind, because unloading in the middle of a steep run like Blowdown was not the brightest idea.....
This post has been edited by hyak.net: 12 August 2004 - 06:59 PM
#45
Posted 12 August 2004 - 02:43 PM
#48
Posted 13 August 2004 - 07:01 AM
NWS, on Aug 12 2004, 02:51 PM, said:
What would be cool is if you had a state by state area where people could post images/fantasy resorts etc.
Powdr
#49
Posted 13 August 2004 - 07:03 AM
KZ, on Aug 12 2004, 03:53 PM, said:
Illustrator allows you to apply slpine smoothed lines. All you have to do is trace the run, and Illustrator smooths it for you.
Powdr
#50
Posted 13 August 2004 - 08:01 AM
#51
Posted 13 August 2004 - 08:59 AM
NWS, on Aug 13 2004, 08:01 AM, said:
That would be good start. If some good art comes of it, you could place that into a separate section on the website, or tie it into the Chairlift Gallery images.
Powdr
#54
Posted 29 August 2004 - 10:38 AM
Powdr
PS: off to the Park City Jazz Festival right now. Should be fun!
#55
Posted 29 August 2004 - 09:23 PM
#56
Posted 30 August 2004 - 01:10 PM
I'm not sure I can do much with Stagecoach since the runs are already pretty overgrown and don't show up too well on the aerial images. I have 'cut' newer runs on ski areas that I've imaged up from older aerial photos, but I don't even know where to begin since I've never been to that area and don't know the layout. If some one could help by laying out the runs on a map, I could get started.
On another subject, I found Stagecoach by starting at Steamboat, then navigating South. I noticed that Steamboat (never been there) faces due West. That sure must produce some spring time slop when the sun gets on it (PCMR's slightly West facing slopes are a mess in the spring). Does anyone know how Steamboat holds up snow-wise with such a West facing orientation?
Powdr
#57
Posted 08 January 2005 - 08:57 PM
#58
Posted 08 January 2005 - 09:01 PM
But you could try Google's new image service, Keyhole. It's keyhole.com and it might have a place for canadian users to find pictures for their country.
#59
Posted 09 January 2005 - 11:15 AM
Powdr, on Jun 1 2004, 09:55 AM, said:
Powdr
What program was that photo done with?
All fo the 3-D images look great.
If you have some time on your hands, think you could make a Wildcat Mountain (NH) 3-D? Thanks
