The reuse of old infrastructure in new lifts
Posted 03 August 2015 - 09:13 AM
So my question is, with the Avanti Express lift in mind, when a resort upgrades a lift and reuses infrastructure like tower tubes, does it save money by not needing to purchase as much new infrastructure?
Posted 04 August 2015 - 06:07 PM
Posted 06 August 2015 - 07:15 PM
ss20, on 04 August 2015 - 06:07 PM, said:
52 years is nothing compared to the Planpraz gondola at Chamonix. Before it was replaced in 2010, it reused the bottom terminal building and 6 concrete towers from the original 1928 aerial tram.
This post has been edited by passengerpigeon: 07 August 2015 - 07:22 AM
Posted 08 August 2015 - 08:58 AM
Posted 08 August 2015 - 10:43 AM
(if anyone knows)
This post has been edited by NHskier13: 08 August 2015 - 10:43 AM
Posted 08 August 2015 - 12:23 PM
NHskier13, on 08 August 2015 - 10:43 AM, said:
(if anyone knows)
You can climb them, but they aren't as friendly as climbing a ladder. I wish our Mueller lift with lattice towers had ladders.
Posted 08 August 2015 - 08:38 PM
This post has been edited by Liftkid99: 08 August 2015 - 08:46 PM
Posted 08 August 2015 - 09:19 PM
Posted 30 December 2015 - 07:07 PM
In 2006, The Canyons replaced the Tombstone HSQ (1997 Poma) with a Doppelmayr 6-pack. They reused the tower tubes and bolted the new Doppelmayr crossarms to them.
The remaining parts of the HSQ went to Steamboat and were bolted onto the original Doppelmayr triple towers.
The Doppelmayr chairs were placed on the South Peak and Christie 3 lifts to replace the Yan chairs on those lifts.
I'm guessing the Yan chairs were auctioned and the crossarms, drive, and return from the Sunshine Triple went to scrap.
Posted 30 December 2015 - 08:51 PM
Another good one is the new King Con and Motherlode at PCMR. King Con has all original tower tubes (except number 1), and all new Doppelmayr towerheads with extensions like Avanti at Vail, painted gray. 15 towers on King Con. The new Motherlode, witht 16 towers, uses every towerhead and what looks like every sheave train configuration from King Con, with 16 towers instead of King Con's 15. The 16th tower has a new Doppeltec black plastic tower number, and the rest have the original tower numbers, probably with some rearranging to account for the different profiles. Motherlode has shiny new Doppelmayr galvanized tower tubes, most of which lean downhill (vs. the vertical towers King Con has). The CTEC catwalks aren't horizontal on top of the new towers (usually CTEC built vertical towers, and when they had an angled one, the front catwalk would be flat to compensate).
Question on cost savings - Motherlode needs 12 hold-down sheaves at the bottom terminal, and the original King Con towerhead had 8-rockers. Here, they built two depression towers at the bottom terminal - one that reuses the tower tube and original towerhead from King Con with 8-rockers, and a new Doppelmayr tower with 4 on each side. How is that cheaper or easier than one all-new 12-rocker Doppelmayr tower? They already bought a new tube and towerhead, and it would have saved them extra concrete.
For the record, it sounds like the old Motherlode Yan towers were scrapped. Some of the chairs were auctioned off to the public.
Last one: the First Time high speed quad (2004 Doppeltec) at PCMR uses the full towers and CTEC towerheads from the old First Time triple (mid-90s CTEC), which was reinstalled (with all new Doppeltec towers) as the Silver Star lift. They rearranged some of the sheaves on the new HSQ, and the CTEC catwalks don't match up with how many sheaves on each tower anymore. Silver Star uses the CTEC terminals and chairs with the Doppelmayr catwalks, which are mounted below the crossarms. Silver Star is really steep out of the bottom terminal, and for a few years you could easily reach out and touch the catwalk (I tried) on tower 2 sitting on the chair as you went by - it was only a few inches away from the top of the chair with the short CTEC fixed grip hanger arms. They removed that catwalk a few years ago.
Last tidbit: Silver Lake at Deer Valley has two sets of numbers on each tower that was reused from the Yan triple, which had the numbers attached directly below the top of the tower tube where the crossarm attached.
