Lowest & Highest Capacity Lifts
40 replies to this topic
#21 SkiDaBird
Posted 11 May 2015 - 07:29 PM
Imperial at Breck is under 1000 pph correct?
#22 DonaldMReif
Posted 12 May 2015 - 10:39 PM
When Imperial opened, it had just 15 chairs on it. They eventually doubled the number of chairs to the current 30 chairs about a year or so later.
#23 Aussierob
Posted 23 May 2015 - 08:22 PM
Jersey Cream at Blackcomb is 2864 pph and we do run it at full speed. HSQ
#24 llamborghinii
  • 26 Posts:
Posted 26 June 2015 - 08:07 PM
Was just about to mention imperial express. I'm not sure how they decide how many chairs are on the rope, but I saw both 25 and 30 at different times last season.
#25 llamborghinii
  • 26 Posts:
Posted 26 June 2015 - 08:08 PM
I believe the High Rustler lift at Alta has 7 chairs as well. I can't think of any lift with fewer chairs than that.
#26 DonaldMReif
Posted 26 June 2015 - 10:14 PM
Rustler has just six chairs.
#27 passengerpigeon
  • 50 Posts:
  • Interests:Skiing, ski lifts and ski areas, among other things
Posted 01 August 2015 - 11:20 PM
Fixed grip single:
Lowest capacity - Chvatimech, Valaská-Chvatimech, 150pph
Highest capacity - Gospinca, Krvavec, 1000pph
#28 ss20
  • 42 Posts:
  • Interests:Skiing, Skilifts, ski area history.
Posted 02 August 2015 - 07:58 PM
Mount Snow claim's their in-house chain-driven double chairs from the 50s and 60s had a capacity of 1200 pph. Pretty remarkable for the time.
Ski Instructor at Thunder Ridge... 300 vertical feet 45 minutes north of New York City. 3 Borvig chairs from the 60s and early 70s.
#29 snoloco
Posted 30 December 2015 - 06:59 PM
I know I mentioned the Pony Express at Steamboat for being low capacity. I read in their master plan that when it was installed in 1998 it had a capacity of 1200 pph which it still has today. However, it was built with the option to add chairs and increase to 1,800 pph which they want to do when snowmaking is added to Longhorn and Middle Rib. I rode it today and it has few towers for a 5,000 foot long lift (only 15 including initial hold down). It definitely can't do more than 1800
#30 Smacpats
  • 217 Posts:
Posted 17 April 2016 - 04:15 AM
It looks like sunday river express, white peaks express, jordan bowl express, Carpenter, snowshed, Superstar and the old Siberia (replaced by HSS this year) are all listed as 3k (HSQs)
http://www.skilifts....sr/sre/sre.html
http://www.skilifts....ille/wp/wp.html
http://www.skilifts....sr/jbe/jbe.html
http://www.skilifts....r/carpenter.htm
http://www.skilifts....ria/siberia.htm
http://www.skilifts....d/snowshed.html
http://www.skilifts..../superstar.html
This post has been edited by Smacpats: 17 April 2016 - 04:17 AM
#31 liftmech
Posted 18 April 2016 - 11:18 AM
Our '11 Doppelmayr has 15 towers and runs 2400 PPH. Towers have very little to do with capacity, more the overall load and length of a lift. By that logic mine should do an ungodly number at 35 towers :wink:
#32 snoloco
Posted 18 April 2016 - 11:21 AM
Pony Express has very widely spaced towers and if it had twice as many chairs, it would drag on the ground because it would sag so much. According to Steamboat's master plan, that lift was built with 1,200 pph, but designed to be upgraded to 1,800.
#33 liftmech
Posted 18 April 2016 - 11:25 AM
I guess I'm not making myself clear. If they upgraded the capacity the tension would be correspondingly higher, and the carriers would still not drag on the ground. I understand that the master plan says the lift is only good to 1800 PPH; my point is that the number of towers affects capacity much less than you think. The lift here that I was referring to is also 5000' long.
#34 snoloco
Posted 18 April 2016 - 11:27 AM
I read the remonteesmecaniques page for both lifts. The towers seem about equally spaced on both, maybe slightly more on Pony. Didn't know that lifts with a higher capacity usually run at a higher tension. That would keep the chairs from hanging too low.
#35 liftmech
Posted 18 April 2016 - 11:39 AM
Yup. I have two tension settings for my lift; 95 bar at 2400 and 105 at 2800.
#36 snoloco
Posted 18 April 2016 - 11:43 AM
So it's 2,400 now and it would have the higher tension if upgraded to 2,800m
#37 liftmech
Posted 20 April 2016 - 06:17 AM
Correct. Although seeing how many problems people have loading now, 2800 PPH would suck. The thing would never run well.
#38 alexboesen
  • 59 Posts:
Posted 20 April 2016 - 08:35 AM
Imperial Express at Breckenridge is at 600 PPH
Another lift for the list - Squaw Valley Funitel 4000 PPH
#39 2milehi
  • 1,027 Posts:
Posted 20 April 2016 - 11:31 AM
600 PPH means 24 seconds between chairs. This seem a little excessive from what I remember (15 chairs on line during early season).
#40 skierdude9450
Posted 20 April 2016 - 07:16 PM
Imperial Express was built originally with 15 carriers for 600 p/h, however 15 additional carriers were added the first year bringing the total capacity to 1200 p/h.
