Some of mine include the Six Pack at Ragged.
Originally, the lift was built as a 90 degree load. That was okay except the lift lines (or maze, as I hear it's referred to) are in the opposite direction of where skiers come in. So unless you stay to the right of exhibition, you need to skate across the base area then snake around the line and then ski up to the lift.
Recently, they have changed the lift to inline loading. The line/maze, however, still points in the same direction. Now that the lift is an inline, the maze had a small extension downhill, about 10 feet or so. (so that skiers can do a full 180 degree turn then go into the small straight leading up to the lift) That wouldn't be too bad of a problem if the Elmwood lodge wasn't so close. Now there's a tiny space to squeeze through to get to the line, assuming that you're sharing that path with some skiing traffic.
If the lift was moved uphill, the small path just uphill of tower 3 which can be used for people taking village green to get to the load line would probably be eliminated. However, since the lift would be farther uphill, you could probably fit in a T-shaped line so that skiers from both sides of the mountain could wait in either one without the ones who stayed left of Exhibition (the six pack liftline trail) having to skate back.
I mean, it's not too big of an issue, but it sometimes gets a little annoying after 5 runs left of exhibition and having to skate back to the six.
Here are some photos to give readers a visual:
Looking at the bottom of the six from the base of the spear mountain express:
Six Pack 2015 Bottom 1.jpg (996.51K)
What you don't see to the left of the six was on that particular day there was 5 feet of room to snake around the side of the lift, due to the line being close to the lodge. It looks like there is a lot more room, but really, there was a sudden dropoff there and then there was a thin cover of snow on top of the bricks.
Here's the tower which skiers taking village green should cross under to get over to the line. Otherwise you need to skate around. You pretty much lose all of your speed if you went around the right side of the lift, so you need to skate over.
Six Pack Tower 3 2015.jpg (756.38K)
On the other hand, what if the six was a counterclockwise lift, with the 90 degree loading (though i'm sure there is a good reason why they made it an inline load, I don't know what it is) most of the skiing traffic wouldn't need to go around the lift, instead they can ski straight into the line.
So anyways, enough with me. What do you think are some of the setups that you think could be fixed, and what do you think should be done?
