Tramway Guy, on 02 March 2015 - 11:50 AM, said:
chopped off the rest of the paragraph to focus on the first sentence. Agreed that all chair lifts are designed to withstand normally imposed loads and the safety factor is increased by several factors above that by design decisions made by engineers. However one would think that if a ski lift designer has not already done a test of dropping VERY BIG live trees on a similarly designed lift line, then the VERY BIG trees need to be cut back from the liftline of any new lift, at the time of the installation of the lift, or the skilift needs to be installed farther away from the treeline, so that the tops of the trees cannot hit the ski lift cable. (simply looking at already established practice in the ski lift building industry over the past 60 years. People learned stuff from seeing others build ski lifts and from seeing those lifts exposed to different weather conditions. ) If the decision is made to leave the trees in place so that the mid section of live trees (or even dead but not rotten) can make contact with the ski lift cable, then really one can say that the lift has NOT been designed and tested for normally imposed loads and conditions.Someone did not do designing, they did hoping. Because in real life trees do fall down. I think that most people would consider trees falling across the path of a ski lift liftline to be a normally foreseeable event over the course of the 30 to 40 year life of a chairlift. One would normally expect that the towers would be made taller so that the tops of trees cannot hit the cable on the way down, or the tops of the trees would be cut off enough so that the remaining part of the tree cannot damage the chairlift on the way down. Since looking at the pictures, of the damaged lift in question, it looks like the trees are softwood trees that do not take well to having the top half lopped off, the only option would be to make the liftline right of way wider. Thats the way it has been at every ski area I have ever ridden a ski lift at. Shame
This post has been edited by Andy1962: 02 March 2015 - 07:03 PM
