WBSKI, on Oct 21 2006, 05:07 PM, said:
That seems sort of pointless to not have a HSQ because when they expand they are definitely going to need a high capacity lift running from the base.
Seeing as though as though a HSQ and a FGQ have nearly the same capacity, having silverlode be a FGQ would not be an issue. My personal opinion is that they put in a HSQ in place of motherlode, then replace red with motherlode. Extra chairs from the above switch could be used to upgrade capacity on silverlode. In reality, if they do replace silverlode with a FGQ, I would think in that case that it would be and idea to use the parts from silverlode to replace the T-bar. There could be some circumstance that would make that hard though.
