Who makes this?
26 replies to this topic
#21 seilbahnbilder.ch
  • 152 Posts:
Posted 17 February 2011 - 09:35 AM
http://alpinforum.co...php?f=39&t=8351
http://www.seilbahnbilder.ch - the website about skilifts in Switzerland!
#22 vonroll101
  • 61 Posts:
  • Interests:vonroll type 101s Early detachable lifts
Posted 21 February 2011 - 07:00 PM
View Postseilbahnbilder.ch, on 17 February 2011 - 09:35 AM, said:
Very cool..Thanks :biggrin:
#23 vonroll101
  • 61 Posts:
Posted 21 February 2011 - 07:08 PM
Here is the full diagram on a 1945 VR101 grip.Attached File  gripping device.pdf (1.82MB)
#24 C W Craven
  • 35 Posts:
  • Interests:Historic model railroading 12 inches to the foot scale.
Posted 22 February 2011 - 11:13 AM
Just a note,
The drawing attached by vonroll101 is for a 1970's era VR-101 2 passenger left hand up grip.
Earlier versions included 1 large nut and cotter pin on the hanger block instead of the douoble bearing nut tab washer shown.
Earlier versions also had "f" style lock levers instead of the bar stock type and the grip cases were cast steel and not fabricated/welded as shown in the drawing.
The drawing also shows a nutted lifting roller axle, earlier versions were cotter pined.
There are also some other improvements that have been made over the years, I would have to look thru the Puyallup (1962 Seattle Fair) Skyride drawings.
C W
#25 vonroll101
  • 61 Posts:
Posted 22 February 2011 - 06:47 PM
I have a old Vr101 grip from Aquarena Springs as well.CW,do you still work on the VR101s?
This post has been edited by vonroll101: 22 February 2011 - 06:49 PM
#26 C W Craven
  • 35 Posts:
Posted 23 February 2011 - 03:26 PM
Yes I do, as general manager of the Puyallup Skyride.
As I recall the springs was a 2 passenger grip (3 passenger cabins), does yours have the "F" lock lever or the bar stock type, and is it a cast case or welded?
C W
#27 vonroll101
  • 61 Posts:
Posted 24 February 2011 - 04:52 PM
The VR101 grip in the picture you see is a welded case.Its from the former Bronx Zoo Skyride.The other is a all cast with the F locking lever.25 mm jaws.Its from the 1962 Vonroll 2 passenger at the Aquarena Springs park..
