Detachable Chairlift Midstations
#21
Posted 01 February 2011 - 05:18 PM
1. Half stations, where chairs detach going up but bypass the midstation on raised towers going downhill. Examples: the Village Express at Snowmass, West Buttermilk Express at Buttermilk, Palmer at Timberline, Orange Bubble at The Canyons, etc. These midstations occur when the lift follows a straight line.
2. I've been on a number of lifts where chairs detach in both directions. These are cases where the midstation functions as a turning station. The Peak 8 SuperConnect at Breck, the Christie Peak Express at Steamboat, and a number of gondolas, like the BreckConnect, feature this.
#22
Posted 04 February 2011 - 10:46 AM
The Sunshine Village Gondola at Banff has an angle station where you cannot get on or off.
The Peak 8 Super Connect at Breckenridge.
The Collins Express at Alta.
The midstation on Palmer at Timberline is the only one-sided midstation I can find a picture of right now.
#23
Posted 04 February 2011 - 11:41 AM
If they do slow down, what is the reasoning?
Cameron.
(No, I'm not the same Cameron who knows everything about ski-lifts!)
#24
Posted 04 February 2011 - 12:23 PM
Cameron.
Yes, they do slow down. Perhaps because making a turn at 1000 fpm would cause the carriers to swing a lot?
Posted 04 February 2011 - 01:27 PM
Any detachable midstations where the uphill side of the line is on the inside of the turn?
Number of downloads: 84 -
#26
Posted 04 February 2011 - 03:12 PM
Not that I've seen. On all lifts with midstations that I have found, the uphill line is to the outside of the turn, whether left (if turning right) or vice-versa. Besides, such a midstation would have to be pretty high off the ground depending on the design.
#28
Posted 04 February 2011 - 04:15 PM
Cameron.
If you've ever ridden one of the old Poma stick lifts with a decent corner, you would know that if they are cranked up to run at 1000 feet per minute, then skiers can easily get airbourne as they go around the corner. And that's on a surface lift.
I hate to think of the angle that chairs would swing out if they went around a bend at that speed!
#29
Posted 05 February 2011 - 01:09 AM
Chair 6 (Riva Bahn) at Vail, but it's only maybe a 2 degree turn.
#30
Posted 05 February 2011 - 09:20 AM
skierdude9450, on 05 February 2011 - 01:09 AM, said:
And it should be noted that Riva Bahn only has one turn on it, not two as the map might suggest at first glance, because those turns in the line are actually representing the lift going down the side of a ridge after the midstation.
