floridaskier, on 27 August 2010 - 05:40 AM, said:
1. Abandon the village for day skiers. Realign the Red Hawk lift to start right in the middle of the hotels, and I realigned the gondola and Cabriolet to be by the bottom terminal of the Golden Eagle HSQ to the right of the village. Build a real base lodge for day skiers down there like every other resort has.
2. Sunrise lift is a transfer to Tombstone. It's not very far. Alternatively, just build a road and a parking lot there
3. Snow Canyon lift realigned so it's much longer and doesn't go from nowhere to nowhere. Build a new lodge on the site of old Buffalo Bob's at the bottom of Super Condor to replace the head-scratcher location (and terrible menu) of the Sun Lodge.
4. Silverado lift added to make it easier to do laps on the north-facing side of Lookout Peak. ParkWest had a lift in this alignment.
5. Lookout lift is renamed and realigned to start right next to the gondola summit and end at the same place for two-way transfers. This was the best lift ASC ever installed.
6. Extend Saddleback to the top of the ridge and add more terrain.
7. New Red Pine lift starts at the Red Pine Lodge and makes use of the wasted north-facing space behind and above Tombstone and below 9990. It's not too steep in this area, and it would add some nice mid-mountain intermediate terrain, which is sorely lacking right now.
8. Tombstone, Super Condor, and 9990 remain exactly as they are. ASC got these right.
9. Peak 5 lift replaced and extended uhigher up the ridge. This would be some tough terrain up here, and a green cattrack back to the bottom of 9990 would be needed
10. Dreamscape lift replaced with a high speed quad starting below where Dreamcatcher is now. Build a lodge down there. Day Break high speed quad goes from there to the top of Peak 5 to make it easier to get back and to add some good skiing there.
11. Dreamcatcher lift would be up the other side of Iron Mountain from the new lift.
12. New base lodge where Iron Mountain and Timberline lifts are now, with parking and a restaurant. From there, the Royal lift adds skiing along the actual fall line in the vast wasteland currently traversed by the awful Harmony run. the Tranquility lift has a midstation to take people back to Tombstone from the south side of the resort.
Give me $100 million and I'll make it happen. What do you all think?
Wow, you're certainly dreaming big on this one. It's an ambitious plan but I like what your thinking.
Proving access to the southern peaks, like 9900, 5 Dreamscape through a new access point is a simple and brilliant idea. Right now, with everything funneling to the Tombstone lift, it's a mess to get back.
The Canyons really have a challenge in bulding this resort the right way. This is what happens when you put a ski resort in a bunch of ravines. I'd personally do more than just realign the gondola too. If I've taken 2 lifts already, I want to get some real skiing done.
I have several friends in Utah who never go near the Canyons due to the poor lift structure, it's a shame the lifts hold back good terrain.
