Lift Speeds
#25
Posted 18 March 2004 - 06:20 PM
#28
Posted 19 March 2004 - 06:24 AM
1100/60 to get feet per second, then divide again by 3.28084 (the feet-metres magic number) to get metres per second.
To go from m/s to fpm, run the formula backwards- m/s x 3.28084, then x 60= fpm
#30
Posted 19 March 2004 - 06:42 PM
Dr Frankenstein, on Mar 18 2004, 06:20 PM, said:
We don't estimate our FPM speeds... Red runs at 504 fpm and 2.56m/s. T-bar 590 which is 3.0m/s.
#31
Posted 19 March 2004 - 10:27 PM
Lifts are usually run full speeds on crowded days so that lift lines are shorter becasue the chair running full speed has a higher capicity than a slower running chair.
#32
Posted 21 March 2004 - 05:29 PM
I mean in the SAM and many other books. In the last lift survey, vou can see that the Orford chondola runs at 1000 FPM, so 5.08 m/s. The real speed of this lift is 948 FPM, exactly 5.00 m/s.
#33
Posted 21 March 2004 - 09:33 PM
#34
Posted 22 March 2004 - 05:24 AM
So all of these speeds assume that the speed meter is calibrated correctly. Do any of you check the calibration of the meters?
#35
Posted 22 March 2004 - 02:08 PM
#40
Posted 23 March 2004 - 09:01 PM
