New Lift Construction Photos 2009
trooper1556
03 Nov 2009
Wildhorse gondola in Steamboat:
I tried to attach these photos with no luck, so here they are linked to photobucket:
Tower 8 on the ground. 9,10 & the top terminal standing in the distance, also snowmaking on Vogue & Stampede:
Looking down the line:
Top station detail:
Top station detail:
Lift Kid
03 Nov 2009
Looks like it's coming along nicely. Big improvement from the last time I saw that terminal which was on the computer at LPOA.
Lift Kid
08 Nov 2009
trooper1556
09 Nov 2009
Lift Kid, on 08 November 2009 - 02:05 PM, said:
As far as I'm aware, yes.
yup 4 groups of 2 6 passenger cabins, for more info check out:
http://coloradoskihi...p?t=999&start=0
Peter
10 Dec 2009
Some photos of a used Riblet triple going in at Bruce Mound, Wisconsin: http://www.fobmi.org...rlift/Index.htm
Somehow they got the Air National Guard to do the heavy lifting with their helicopter?
iceberg210
10 Dec 2009
I suppose it helps to have friends in high places,
Does anyone know per chance where this triple came from before it ended up in Wisconsin?
nelski
10 Dec 2009
cause otherwise I don't know how you get the Air National Guard to help your ski resort like that.
County park run area. Lift from Superior on list last year
trooper1556
19 Dec 2009
cabins on the line, but still hearing february opening:
jaytrem
01 Jan 2010
Some pics of the new double-double at Big Bear, PA (not my pics)....
http://www.snowjourn...?cid=topic15995
trooper1556
01 Feb 2010
The first of February brought new snow to Steamboat as well as the on schedule opening of Colorado's only new lift for 09/10. It is a short 2-3 minute ride that I'd recomend! It is free to the public so if you make a trip to the 'boat park in the meadows lot & make the short walk to the lower terminal instead of taking the shuttles.
skier2
01 Feb 2010
trooper1556, on 01 February 2010 - 04:30 PM, said:
Very nice, but they probably should have settled for a detachable, since they plan on building out the entire area where the tennis center used to be. Also, is the former location of Ski Time Square Condos, etc, still lying essentially empty? That was bad timing :( The could always focus on less expensive upgrades for the time being, like an overhaul of the existing infrastructure in gondola square.
skiersage
01 Feb 2010
Correct me if I am wrong but I don't think that Steamboat (the company that operates the mountain) payed for this lift to be put in. I remember a press release saying that Intrawest declined to fund this project, otherwise it would have been a detachable lift. If this is the case then it is not fair to say that it was a bad use of money for them.
trooper1556
01 Feb 2010
They did go back & forth on installing a detachable, this lift ended up being fully paid for by the developer of the condo complex next to the bottom terminal (thus why ski time square & other areas have yet to be addressed) - you can read the full history of this lift here: http://coloradoskihi...p?t=999&start=0
The tennis center will remain, but most of the open space around it will be built out. here's a rendering of the approved master plan:
skier2
02 Feb 2010
I knew that Intrawest did not fund the gondola, but look at at that development! A pulse isn't gonna cut it!
Peter
02 Feb 2010
Timing Flats at Whistler taken this weekend.
Number of downloads: 182 -
Number of downloads: 232 -
Number of downloads: 237 -
Number of downloads: 210 -
Number of downloads: 174 -
