←  Skilifts.org Images
1st Hsq In World Found!
Tinel's Photo Tinel 26 Nov 2003
Chains were used (in Switzerland) by:
Garaventa
WSO-Staedelilift
(Baco-)Poma
von Roll
Habegger
Giovanola & frères
Muellerlifts (GMD)
Rowema
KZ's Photo KZ 26 Nov 2003
I think everyone used chains before they found a reliable way to get the tyres to take the carrier around the contour
Eric's Photo Eric 27 Nov 2003
yep
SkiBachelor's Photo SkiBachelor 27 Nov 2003
Another picture of the lift.
Is that at Brek ?
I don't know.
KZ's Photo KZ 27 Nov 2003
Looks alright, good for its age
That doesn't look like the first HSQ found in the world
I wasn't sure, but it does look old.
Kicking Horse's Photo Kicking Horse 27 Nov 2003
That pic is not from Breck. I'm 100% sure that is not breck.
Dr Frankenstein's Photo Dr Frankenstein 28 Nov 2003
Not the same grips, not the same towers, not the same chairs, it's not this lift. :blink:
liftmech's Photo liftmech 28 Nov 2003
Conveyor chains were the first method of moving chairs around the contour, as Cameron noted. I don't know how maintenance-intensive Doppelmayr's are, but Poma's take a week per terminal to work on in the summer. Then there's the small problem of the cadencing system being a 'passive' system, instead of the more modern 'active' tyre banks. A passive system means that the chair comes into the terminal and either is caught by the chain or not. An active system, on the other hand, constantly fine-tunes the spacing of the carriers as they come through, eliminating (or almost) chair collisions.
Dr Frankenstein's Photo Dr Frankenstein 14 Jan 2004
Does the Orange (formerly Quicksilver) chairlift have gravity grips????
floridaskier's Photo floridaskier 29 Feb 2004
I dont think so. I think it had the box-style grip in use until about '94 (?).
(no actual info on this, don't hold me to it)
Dr Frankenstein's Photo Dr Frankenstein 14 Mar 2004
It's not DS grips.
liftmech's Photo liftmech 14 Mar 2004
The former Quicksilver doesn't have DS grips? It must have been retrofitted, then, because the DS grip was the first detachable grip and it was on the Quicksilver when it was at Breckenridge,
floridaskier's Photo floridaskier 15 Mar 2004
The chain spacing system on the older Doppelmayrs like at Vail looks pretty simple. The chair is caught by two sort of hook things that are spaced out as far as the distance between the chairs should be. The chains catch the chair. But what would happen if one of them missed the chain hooks and the next one crashed into it?
SkiBachelor's Photo SkiBachelor 15 Mar 2004
We discussed this a while back with the POMA Angel terminals. If the lift operator was able to see that the chair missed and stopped the lift in time, he would be able to put it on the rail, but if he missed , well there would be a problem. Doppelmayr's seem not to have this problem from what I have seen.
Dr Frankenstein's Photo Dr Frankenstein 15 Mar 2004
The operator at St-Sauveur was going crazy because he didn't wanted to stop the lift! He was running in all the ways!
floridaskier's Photo floridaskier 16 Mar 2004
Do you mean he would put it on the maintainance rail and put it back next time the spot came around, or push it back into the chains that it missed?
