Tower snaps on Excalibur (Blackcomb Mtn)
119 replies to this topic
#41 2milehi
Posted 17 December 2008 - 01:05 PM
View Postaug, on Dec 17 2008, 12:18 PM, said:
In my career I have seen terminal towers (Masts) filled with concrete but I have never seen any line towers constructed this way.
Chatted with a few guys at work and certain towers will get partly filled with concrete (towers in an avalanche area). Also I can see the addition of concrete if a tower needs to be more structurally sturdy.
#42 skisox34
  • 339 Posts:
Posted 17 December 2008 - 01:15 PM
Wow that is a pretty catastrophic tower failure! As people have said...at least no one was hurt! I could see the holes at the bottom of the tower being instituted as a rule by states after this.
#43 shoemaniii
  • 92 Posts:
Posted 17 December 2008 - 02:21 PM
drain holes can fill w/rust flakes, debris. these holes may freeze closed while draining (the recent ice event in new england caused one lift that i know of where line sheaves iced up while turning).
there's no substitute for annual checks, see post #34.
bobp
#44 floridaskier
Posted 17 December 2008 - 03:05 PM
How long would it take for that much water to seep into a tower? And where would it come from? Just snow melting on top of the towerhead? I'm no authority on towers, but this had to be building up for years
#45 skierdude9450
Posted 17 December 2008 - 04:31 PM
It seems like it would be pretty hard to not notice 20 feet of water, or over 4000 gallons by my estimation (that's roughly 15,000 liters), inside a tower. And like floridaskier said, that would take years to accumulate that volume unless there was a very large hole. But it's easy to see how the ice wedging occurred. 16 tons of ice can do a lot of damage.
#46 Lift Kid
Posted 17 December 2008 - 04:48 PM
It's scary what water can do.
#47 Peter
Posted 17 December 2008 - 05:10 PM
Whistler at that elevation does get a lot of rain.
#48 LuvPow
  • 220 Posts:
Posted 17 December 2008 - 05:27 PM
At Mt. Hood Meadows in 04 they poured concrete into some towers on the Vista lift, but that was mainly for snow creep issues I believe
Laurence Sterne
#49 bwilky
  • 25 Posts:
Posted 17 December 2008 - 05:42 PM
Plus its the west coast. We get way to much rain in BC.
Are you guys all checking your towers now?
#50 Emax
  • 2,904 Posts:
Posted 17 December 2008 - 06:58 PM
This "water in the tower" issue has been well worn out in other threads on this forum. Folks have been checking towers for water for at least a year (this is not the first such mishap).
It is a fact that water can get in there - through leaks or normal aspiration of air through imperfect welds. It's hard to make something as large as a tower perfectly waterproof.
Yes - holes can be drilled at the bottom, but that can do as much harm as help. Mostly, it can lead to a false sense of security. The only way to be sure that a tower does not contain a hazardous amount of water is to check it out thoroughly and regularly.
Now let's all stop asking the same questions that have been covered some time ago in discussing a similar incident. Talk solves nothing.
Reading might help...
#51 dapole
  • 24 Posts:
Posted 18 December 2008 - 02:24 AM
So what is the turn around time on getting a lift like this back up and running? I imagine that WB does not want to have the main access point to Blackcomb from the village down, and people to see the accident everyday, over the christmas holiday.
#52 Skiing#1
  • 745 Posts:
Posted 18 December 2008 - 08:18 AM
I am surprised there is no media or no news or no newspapers here in Utah. Yesterday, I saw the video on The Weather Channel, and I didn't catch the name where it is. Thank you for posting news in this website.
I looked the video and read the article. Whistle caused few lifts have problems. I can't believe what happened.
http://www.ctvbc.ctv.ca/servlet/an/local/C...BritishColumbia
This post has been edited by Skiing#1: 18 December 2008 - 08:31 AM
#53 bwilky
  • 25 Posts:
Posted 18 December 2008 - 10:03 AM
I doubt it will be up before the new year.
#54 brad82
  • 71 Posts:
Posted 18 December 2008 - 10:18 AM
Seems like a relatively quick fix for doppelmayr, though. So long as the footing and tower head aren't damaged the midle just needs replacing - I guess its how fast they can ship one out...
Then again, they will probably have to take the cabins off the line to re-align the rope...
This post has been edited by brad82: 18 December 2008 - 10:19 AM
#55 Emax
  • 2,904 Posts:
Posted 18 December 2008 - 10:26 AM
This post has been edited by lastchair_44: 18 December 2008 - 10:39 AM
#56 bwilky
  • 25 Posts:
Posted 18 December 2008 - 11:00 AM
Wouldn't the footing need to be replaced if the whole thing was frozen? It could potentially be weakened.
#57 Aussierob
  • 1,036 Posts:
Posted 18 December 2008 - 11:54 AM
The footing should be fine. All the cabins will be removed and the rope tested. They are currently deciding whether a new tower is needed or the old one can be repaired. I fully expect it to be open for Christmas.
#58 bwilky
  • 25 Posts:
Posted 18 December 2008 - 11:58 AM
Are you going to be working on it? Some close up pictures would be awesome!
#59 Aussierob
  • 1,036 Posts:
Posted 18 December 2008 - 12:11 PM
I won't be around but I'll see if I can get a photo or two. We will be repairing the existing tower.
#60 tahoeistruckin
  • 282 Posts:
Posted 18 December 2008 - 02:44 PM
The last place i want to get news from is the Weather channel, they can't even get the forcast right most of the time.lol
http://www.cnn.com/2008/WORLD/americas/12/...dola/index.html
