aug, on Sep 23 2008, 05:48 PM, said:
If my memory serves me correctly the Retro-Riblet installs were designed by Aerial Engineering ( the Ellis clan) his tower X- arms resemble yans design with the X-arm being closed box tube and the x and y axis through bolt adjustments.
Just a few additions.
The over-under guage lift was designed originally by an east coast engineer. (I will remember his name or look up a file tomorrow)
First Riblet one was built in Costa Rica. Second Riblet one in Dominica.
Costa Rica is a bottom vault drive, top temsion originally from Northstar. Dominica is an overhead bottom drive, bottom tension.
The Riblets were used on two of the installs using the classic Riblet clamp style crossarm with box tubing and x & y adjustment .
The others are CTEC and Doppelmayr CTEC using the Jan Leonard/Mark Ballentyne clamp style Thiokol then CTEC style crossarm.
St. Lucia uses a similiar clamp style crossarm designed by John Dalton and was fabricated in Venezuela.
All the CTEC crossarms use a removable lifting frame. The Riblets use one on the upper crossarm.....the lower one you would rig to the upper crossarm above.
Getting to the zero guage and out of the zero guage is done a couple towers out by canting the sheave assemblies. Lots of shims and custom secondary axles. Hard part was pulling the cable and keeping the cable in the sheaves with no tension.
The Riblets are zero guage. Costa Rica and St. Lucia CTEC/Doppelmayr are standard guage with offset crossarms. (one high road and one low road)
Jamacia is the first zero guage using CTEC/Doppelmayr equipment.
All the cabins (except Jamacia which used chairs) were designed and fabricated in Costa Rica.
None of the Rainforest Trams are jig-backs, they all go around the bullwheels.
No pulse type systems either, all are equally spaced cabins. All cabins are slowed down to creep speed to go around the bullwheels.
Some bullwheels have special support rings to keep the grips in the grooves with all the cabin weight. (7-9 passengers) (each cabin has a guide)
Most cabins have two chair stems and grips, Dominica has four stems and grips. The stems are nounted on a frame that articulates when it goes around the bullwheel so the Riblet type grips dont peel out of the bullwheels.
Built two of them, maintained them all for awhile.
This post has been edited by Outback: 23 September 2008 - 08:44 PM
