Chairlift Loading carpets
#41
Posted 18 September 2008 - 01:07 PM
#42
Posted 18 September 2008 - 05:14 PM
Lift Kid, on Sep 18 2008, 05:07 PM, said:
Perception of speed. Sure the lift runs faster, but if it were my choice, the chair spacing would also be greater. Its hard for people to judge a 6 seconds spacing or a 10 seconds one... just as long as she keeps chuggin away. If someone can't figure on when to 'Go' as the gate opens, better stick to the beginner area carpet. Unloading is key in my mind...I could see that as the bigger problem. I'll see this winter at Boyne, on the new Meadows, a Dopp w/carpet loading
#43
Posted 18 September 2008 - 09:14 PM
To make things more interesting, ANSI doesn't say anything about having a Calvin and Hobbes snowmonster on the ramp either:
#45
Posted 19 September 2008 - 08:45 AM
Skiing#1, on Sep 17 2008, 09:08 PM, said:
I saw the other video about at the top of the lift, one snowboarder (female) removed her board while rode the lift, got off, walked, and carried the board. I will find the video to post later.
I just found one. http://www.youtube.com/watch?v=7OwniRRKtrY...feature=related
Letting any snowboarder ride a lift without 1 foot attached is dangerous. I seen runaway boards and the damage they do. Also skis whom brakes didn't work
#46
Posted 19 September 2008 - 01:34 PM
"Section 4.1.1.2 Capacity and speed
The maximum carrier speed relative to the surface of loading and unloading operations shall not exceed values shown in Table 4-1. The designer shall specify the design capacity in both directions. The speeds listed in Table 4-1 may be increased if a lift is slowed or stopped for loading and unloading, but in no case shall the speed exceed that specified by the designer and established as functional by testing and operational performance..."
"TABLE 4-1"
PASSENGER TYPE SINGLE CHAIR DOUBLE CHAIR TRIPLE CHAIR OTHER CHAIRS
SKIER 600fpm (3.0m/s) 550 (2.8) 500 (2.5) 450 (2.3)
FOOT PASSENGER 350 (1.8) 300 (1.5) 275 (1.4) 250 (1.3)
Clear now??
(Columns don't want to line up, but you can figure it out)
This post has been edited by Lift Dinosaur: 19 September 2008 - 01:40 PM
#47
Posted 20 September 2008 - 06:36 AM
Alot of pictures (gallery), 3-D loading carpets and how it works (download), and different kinds of the lifts include nordic slider.
http://www.chairkid.com/index.php?id=foerd...amp;L=1&L=1
This post has been edited by Skiing#1: 20 September 2008 - 07:12 AM
#48
Posted 20 September 2008 - 07:08 AM
#49
Posted 20 September 2008 - 09:00 AM
"TABLE 4-1"
Clear now??
So, unless a carpet is located at both terminals, a fixed grip quad still can't run faster than 450fpm.? It must be more about helping obtain max. capacity by reducing stops and maybe a slight increase in speed. Our quads are rated at 400 fpm and thats plenty fast with the 42-56ft spacing, respectively. Our clientele tends to handle 375-380fpm well when we are busy.
#50
Posted 20 September 2008 - 01:44 PM
This post has been edited by nathanvg: 20 September 2008 - 01:44 PM
#51
Posted 20 September 2008 - 04:45 PM
nathanvg, on Sep 20 2008, 02:44 PM, said:
Northway at Crystal Mountain runs at 550 fpm, but the capacity is still 1200 pph.
Posted 21 September 2008 - 03:03 PM
A combination of closer spacing, faster speeds, and fewer stops or slows make a lift's uphill capacity higher.
#53
Posted 13 February 2009 - 08:07 PM
http://www.youtube.c...h?v=6HAV36FlRic
Enjoy to see it.
#54
Posted 28 February 2009 - 08:11 PM
you also lived the pain. these carpets were built on existing lifts who's design never contemplated load carpets.
to squeeze c-9 carpet in we had to remove the counterweight shack, trim the counterweight to fit and rig it to
hang 90 degrees offset. the no heat, no drains problems aside the durn things wouldn't track straight. the round
rollers at either end would collect snow and constantly be driven out of alignment. i was able to spend many quality hours in the pits getting to know my favorite.poma techs. to this day it still drives us to drinking. the best magic of these machines was that when we got bought by boyne in 97, they magically disappeared.
This post has been edited by mtn.bob: 28 February 2009 - 08:12 PM
#55
Posted 08 March 2009 - 06:40 AM
I have recently been to Okemo and experienced their loading and unloading carpets and they are awesome. Especially the unloading carpet. You can see a video of how they both work if you go to okemo.com and click the snow report, the video is right before the trail status. In my opinion there should be at least one loading and unloading carpet in the begineers area so there is not as many stops when new skiers try to get on a chair. Im fine with loading both since I'm seasoned but the un/loading carpet makes the experience cooler and more interesting
-Piotr
#56
Posted 08 March 2009 - 10:28 AM
skierdude9450, on Mar 31 2008, 09:00 PM, said:
I've never paid so much attention to Lift 7, so I never knew about this carpet. Is it efficient?
#59
Posted 11 March 2009 - 09:53 AM
cfrankrun58, on Mar 11 2009, 01:45 PM, said:
Yes. A loading carpet runs slower than the speed of the lift but an unloading carpet runs faster than the speed of the lift.
-Ron White
#60
Posted 11 March 2009 - 11:04 AM
skiersage, on Mar 11 2009, 01:53 PM, said:
This is true for a fixed grip, but not true for a detachable, both would need to run faster than the carrier in the loading and unloading zones.
