load testing
54 replies to this topic
#41 Snoqualmie guy
    Snoqualmie guy
  • 1,065 Posts:
Posted 09 November 2007 - 08:45 AM
Does each lift have to have a load test every year?
- Jeff
#42 Allan
Posted 09 November 2007 - 09:12 AM
Once every five years in Canada.
#43 Lift Dinosaur
  • 2,077 Posts:
Posted 09 November 2007 - 10:06 AM
In the U.S., new or relocated installations are required to go through an Acceptance Test with 110% of design load.
For existing installations, they are required to go through Dynamic Testing every seven years, which only requires 100% of design load. :thumbsup:
This post has been edited by Lift Dinosaur: 09 November 2007 - 10:12 AM
#44 EagleAce
  • 716 Posts:
Posted 09 November 2007 - 10:49 AM
View PostKicking Horse, on Nov 9 2007, 06:16 AM, said:
Diesel Power all the way ;)
:biggrin: slight correction, Kicking Horse--
International Diesel Power! :cool:
#45 Shawn
  • 262 Posts:
  • Interests:Many
Posted 09 November 2007 - 01:30 PM
Heres a picture from yesterday.
#46 shelldog
  • 64 Posts:
Posted 13 November 2007 - 07:57 AM
Dino, In your travels, have you found that most lifts are dynamic tested at 100% or 110%? I have heard that some are tested at 110% to get comparable results to the acceptance test.
The difference between genius and stupidity is that genius has its limits. ~ Albert Einstein
#47 shoemaniii
  • 92 Posts:
Posted 13 November 2007 - 02:35 PM
vt's 7-year dynamic testing uses 110% of design load, have since 1982. all lift components are designed for 110%, no problems other than apu's that used to pass sometimes have run out of steam, or whatever. a tune-up usually does the trick. if an insurance/fed forest inspector requires an "official" procedure, we simply take the loaded portion out of the original designer's acceptance test. the 110% load gives the area some level of comfort that his apu has the 'nads to pull the load when needed.
bobp
#48 Lift Dinosaur
  • 2,077 Posts:
Posted 13 November 2007 - 05:22 PM
I have found that most areas are doing the 100% (even though a lot of smaller, remote areas are behind the curve in regards to B77-1999). Many areas with "older lifts" do not have the original acceptance test documentation or a copy of the standard to which the installation was originally tested.
The reasoning for 110% to get comparable data makes good sense. Especially for a lift that is in the 10-20 year old range. MHO
#49 spark's
  • 80 Posts:
Posted 14 November 2007 - 04:54 PM
bobp
Ohhh she'll pass... :wink:
They say a monkey can turn a wrench... I hope it's an adjustable....
#50 Emax
  • 2,904 Posts:
Posted 15 November 2007 - 07:28 PM
While on the subject of load testing, I wish to congratulate the engineers, technicians and fabricators at Doppelmayr - Cetec on a job very well done. We completed our load tests and final inspections today on two new lifts. I could not find a rough edge. They are both machines that are very well executed - from top to bottom.
Thanks guys, I sold you short - but will not do it again.
Bud
#51 hyak.net
  • 346 Posts:
  • Interests:Snowboarding, Basketball, Ski History....
Posted 16 November 2007 - 07:34 AM
Bud
I don't know if this video has been posted here before, but today I found this load test video very interesting.
http://www.youtube.c...v=FwPP4i7ENvQ
#52 Snoqualmie guy
    Snoqualmie guy
  • 1,065 Posts:
Posted 16 November 2007 - 03:14 PM
I think I've seen it before somewhere, not sure if it was here though.
- Jeff
#53 Phoenix
  • 79 Posts:
Posted 16 November 2007 - 04:21 PM
Yeah...that is the Eskimo Rollback Test done at Winter Park. It is already on the site and was popular topic in July and August.
#54 RibStaThiok
Posted 16 November 2007 - 05:29 PM
I'd like to see the Eskimo Express go through that...
#55 bwilky
  • 25 Posts:
Posted 29 December 2007 - 11:08 PM
View PostSnoqualmie guy, on Oct 3 2007, 05:31 PM, said:
That lift has alot of sag in the cable. The only lift I've seen that had that was a '88 Riblet triple, Sliver Fir at Ski Acres.
You think thats alot of sag? Just look at the Mystery Peek double hall on seymour. On a busy day with people coming out of the cafe (LOL) you can get a 30 ft difference (I think its more) from the returning chairs. It would be amazing to be a lifty riding down.
This post has been edited by bwilky: 29 December 2007 - 11:08 PM
