The Safety Bar...
#61
Posted 25 June 2007 - 08:09 PM
#63
Posted 26 June 2007 - 05:36 PM
As for the vermont law, requireing all lifts to have a safety bar which will not yield to forward pressure, this seems to only be selectivly enforced. One example is the single chair at Mad River Glen, the footrest, is not a pull down, but rather is hinged on the side of the chair, that you close like a gate, i think some older mueller centerpoles had this design. I've ridden this chair many times and i can tell you, to open the bar, you push it forward, it will definatly yield to forward pressure. The original single chair is currently being dismantled, but is being restored, it will have new single chairs with the same style footrest.
Also in vermont, i can tell you that there does exist a chairlift without restraint bars, its the Ski Baba lift at Mount Snow. In all fairness, this lift is truly a beginner lift and is maybe 5 feet off the ground. Mt. Snow also had another one, a really cool home-built lift, the Mixing Bowl chair, it was chain driven on a track, went really slow, was also a beginner lift, it was quite unique, it was low off the ground, but I do believe though i'm not 100% sure that it did not have safety bars. It has since been replaced with a magic carpet - it was a pretty short lift. So it seems like the VT tramway board is not steadfast in this rule.
As for me personally, i was a ski racer and a ski instructor, as a racer, never used them, as an instructor, I was required to, so now i really only use them on long lifts that have footrests, except on Hall's, there footrests are too short for a tall guy like myself, so I never use them if i'm on a Hall lift, those carriers are really not made for tall people, and one of the mountains I ski regularly, all 8 lifts are halls, i never use the bar there.
#64
Posted 28 November 2007 - 05:14 PM
Skier Falls from Dipper Express at Heavenly
I guess it is just a habit that one needs to start. I can be riding with five other instructors on a six-pack and we do not use the safety bar. Then again, helmets did not become mainstream until recently, so maybe we can make it a habit if it becomes required (just like seatbelts).
As one gets older, it is funny how things like life insurance and getting permanently injured or worse crosses one's mind. I stopped doing backflips years ago when I realized I was not an invincible person (and with the birth of my now seven year-old son). Puts things into perspective.
Too bad there is not a way to make a safety bar drop and rise automatically when loading and unloading respectively. The moving parts that would be required for the carrier would probably be expensive, hard to service and retrofit to existing carriers, and subject to breakdown when riders try to override or turn off the safety bar feature (such as try to stop the bar from dropping down). Plus, if the lift breaks down for some reason, there would have to be some kind of safety release to allow ski patrol to evac riders. However, it would have to be located in a place that the patrollers can access, but that the guest cannot reach while riding the carrier.
Do any of you that do or have worked in lift maintenance and lift development know of anything that has been tried with an automatic safety bar feature? (Emax...Liftmech...any others out there)?
Of course, the best safety feature is common sense.
This post has been edited by Phoenix: 28 November 2007 - 05:35 PM
#65
Posted 28 November 2007 - 09:22 PM
This post has been edited by Skier: 28 November 2007 - 09:22 PM
Posted 28 November 2007 - 11:55 PM
As Lawyers became more prevalent so did restraining bars.
The earlier bars such as on the old mad river lift (new ones I believe will be different per ANSI code) were primarily for resting your legs, the upper bar that came across in the lap area was a handle to close the foot rest.
I have heard many folks mention that the restraining bar will not hold you in the event that one were to fall against it, but I have not heard of one single documented case to back this up. Yes, some kids have slid under the bar.
I have heard many documented cases of people (that were not using the restraining bar that was provided) that have fallen out of a chair.
As a side note, the restraining bar as provided to the ski area will hold the pressure of a skier going against it.
Yes, metal will fatigue near a weld over time, it is up to you the mechanic to know this and maintain the product in the appropriate manner.
Some of the older lifts do have welds in a free length of bar in front of the skiers lap. And these welds do break.
When this has happened, I did not just weld the broken joint I would add an internal reinforcing piece as a backer for my weld.
This post has been edited by chasl: 28 November 2007 - 11:59 PM
#68
Posted 29 November 2007 - 08:49 PM
#70
Posted 29 November 2007 - 08:57 PM
Snoqualmie guy, on Nov 29 2007, 08:54 PM, said:
I know, but if a high-speed lift suddenly stopped, you'd be more likely to fly off, right?
#71
Posted 29 November 2007 - 08:58 PM
If you are on a lift that is hauling, on a relatively flat section, and it stops super fast, and the chairs are covered in those vinyl seat pads, and it is icing up, and you have ice on your pants....I could see it being very easy to fly off if you are leaning forward. Don't say that these conditions are hard to have occur. Think of a powder day where it is warming up and a snowboarder is on the lift (yes, I'm a snowboarder, and yes, some of us sit down, which causes snow and ice to deposit on the nether region) and somebody inexperienced falls at the bottom.
On the flip side, with a standard rubber (foam rubber?) seat, on a steep uphill section, when the lift is already going slow, even emergency shut down/brake is unlikely to toss you.
Does the bar do all things, for all people, in all circumstances? No, but it can help. I have, for a fact, slid forward more than once on lifts. Would I have fallen? Probably not because I lean back and am careful, but if I had been leaning forward, it is very possible. As for the people who slam it down on your head, I tend to get rude at that point.
#72
Posted 29 November 2007 - 09:59 PM
Posted 29 November 2007 - 11:14 PM
#74
Posted 30 November 2007 - 05:53 AM
Skier, on Nov 29 2007, 10:59 PM, said:
That is correct. After swing forward first then back AND then the chair go up and down a bit little.
#75
Posted 30 November 2007 - 09:43 AM
This post has been edited by aug: 30 November 2007 - 09:45 AM
#76
Posted 30 November 2007 - 09:54 AM
zeedotcom, on Nov 29 2007, 09:58 PM, said:
If it stops 'super fast' there is something wrong with the braking system. Yes, there is a maximum stopping distance, but there is also a minimum distance. From my experience both riding the lifts and working on them, abrupt stops are not exactly normal and I'd go as far as to say almost nonexistent.
Chasl- I once got my @$$ chewed for welding a bar without the backing material
#80
Posted 01 December 2007 - 11:15 AM
It seems to me that would depend on how easily the chair swings, and on detachable chairlifts where this scenario would most likely occur do not swing back and forth very easily. Think about what happens when you slam on the brakes. You go foward. I have been subject to about a 150 foot stop at 1100 fpm. Yes, I did have the saftey bar down. Would I have fallen if it wasn't down? I think not. The lifts are designed to be safe and not throw someone off during an emergency stop with or without the bars down. If they didn't take that into consideration, there would be a considerably larger number of accidents in the industry. If you just use common sense and don't lean over to adjust a binding or a buckle or something, you won't fall off the lift even in an emergency stop.
