load testing
Emax's Photo Emax 05 Oct 2007
Maybe I missed something - but didn't this thread begin with the question: "What do some of you folks use for load testing a lift:dry" ?
Wet testing is works well for most folks - especially if you choose a method that allows pissing the water out from the containers gradually on the trip back down the mountain. No heavy lifting, no huge puddles at the top.
One can have bladders custom made by water mattress manufacturers for a pretty low dollar. These things fill uniformly, drain slowly on the downward return trip and store in a very small place. Unlike boxes lined with plastic bags, they're reusable - not creating a mountain of garbage after the test.
But this thread isn't about that - or any other "wet" media - the specification was "dry". Any real ideas - beyond sandbags? I've seen beer kegs (full ones) used - but that only makes sense if you have a high-traffic F&B service at the top of the lift... or a very thirsty load test crew.
Dr Frankenstein's Photo Dr Frankenstein 08 Oct 2007
I'd say the "dry:" word on the first post is a messed-up code for the :dry: emoticon, Emax.
chasl's Photo chasl 09 Oct 2007
Gravel always seemed like a good idea, most areas have it and I know of one are that used gravel in sand bags and use the gravel to build the unload ramp after the testing was complete.
This post has been edited by chasl: 09 October 2007 - 01:30 AM
Emax's Photo Emax 09 Oct 2007
I guess that's possible.
skisox34's Photo skisox34 10 Oct 2007
You want the load test crew to make it back down the mountain too!
Emax's Photo Emax 10 Oct 2007
If you're planning such a test - and your crew is concerned about this - contact me ASAP.
There is a crew here ready to help you with this problem.
aug's Photo aug 10 Oct 2007
On Mt Hood the prefered medium for load testing is rock (snow conditioning) salt.
EagleAce's Photo EagleAce 10 Oct 2007
:beer: :cheers: ya use what's available! :biggrin:
Allan's Photo Allan 25 Oct 2007
A shot from the load test on Tuesday!
RibStaThiok's Photo RibStaThiok 26 Oct 2007
How well did that old beauty do there Allan?
Allan's Photo Allan 26 Oct 2007
Everything went perfect until we coupled the evac drive - which wouldn't drive the load. We had a new carb installed on the evac drive and it may just need some fine tuning. So we'll load the buckets again when it's all tuned up!
What type of motor? (Primary and Evac)
cjb's Photo cjb 27 Oct 2007
When we load tested one of our lifts a couple of years ago we had an aux that wouldn't move the load at the required speed. We did some fine tuning and it helped a bit but ended up changing the aux pulley size to something slightly smaller. When we looked at the original load test documents we saw that it BARELY made 100fpm brand new 25 years ago. This was a chrysler industrial 413.
Allan's Photo Allan 27 Oct 2007
Prime mover is a Avtek 250 HP electric, evac is a Ford 503 cid v8 (gas) industrial motor... looks like someone plunked a front end of a tractor in the drive station!
Wish it was an option to change a pulley! This thing has a chain coupling with a 2:1 reducer in the drive line. And when I say it wouldn't drive the load - it wouldn't even move it.
Kicking Horse's Photo Kicking Horse 28 Oct 2007
Did the evac motor move the lift empty???
Allan's Photo Allan 28 Oct 2007
Yup it did!
RibStaThiok's Photo RibStaThiok 06 Nov 2007
 Allan, on Oct 28 2007, 03:29 PM, said:
Yup it did!
Were you guys able to get the problem solved on that Evac?
Allan's Photo Allan 06 Nov 2007
Yep! A brand new Edelbrock carb was the trick. The old girl has NEVER ran so well. :thumbsup:
EagleAce's Photo EagleAce 08 Nov 2007
as long as it's not a "QuadraJUNK"! :laugh:
:dry: everyone here KNOWS my suggestion for an auxillary!
Kicking Horse's Photo Kicking Horse 09 Nov 2007
Diesel Power all the way ;)
