skisox34
16 Aug 2007
On the topic of bullwheels when I worked the Superstar drive terminal in 1999-2002 that bullwheel was WARPED. There was at least an inch or two difference at different points on the bullwheel as far as height goes. Does anyone know if this was ever fixed?? I know at one point the E-Brake weld actually failed because of this and the pad actually fell through the skin requiring the lift to be shut down for the rest of the day until the pad could be re-welded!
LiftTech
16 Aug 2007
Off topic but, First, that type of Yan wheel cannot be straightened, second the Warped wheel did not cause the failure, and lastly the pad did not fail. However what did cause the failure is design, the force applied from the air bags to open the unit was greater than the strength of the steel.
The failure:
The fix:
The failure:
The fix:
vons
16 Aug 2007
When you wish the web cam was not on
Peter
16 Aug 2007
how did they manage that?
This post has been edited by Skier: 16 August 2007 - 06:51 PM
Lift Dinosaur
16 Aug 2007
No one hurt, I hope....
This post has been edited by Lift Dinosaur: 16 August 2007 - 02:51 PM
lastchair_44
16 Aug 2007
lastchair_44
16 Aug 2007
His load may have shifted? I'm not 100% sure. He's damn lucky though.
Peter
16 Aug 2007
When I first looked at it I thought it had fallen off the tram, as I have seen pictures of them hanging similar pieces of machinery from the cabins.
Allan
17 Aug 2007
The lastest shot from our marketing department. The return station and all towers are standing now. Sorry for the lack of shots on my part - been on holidays since the last week of July, except for three days when I was back pulling YAN carriers apart.
Lift Kid
17 Aug 2007
Here are some shots of new Lift 10's controls at the LPOA shop. I had a tour today over there at the facilities! I have more pictures, if anyone would like to see them!
Return Controls:
Drive Controls:
Control Desks (both):
Return Controls:
Drive Controls:
Peter
17 Aug 2007
I would love to see some more pictures if you have time to post them.
Lift Kid
17 Aug 2007
I'd be happy to! However, some are a bit blurry due to lighting and other things.
Here's some more:
A bullwheel being made.
The terminal skin for Snowmass.
The drive component base for Lift 10 at Vail. (this holds the Gear box, 2 diesels, 1 electric and the bullwheel)
Another shot of the Snowmass skin.
Sheave wheels almost done being assembled.
An Omega Quad contour skin.
Tower heads all wired for safeties, waiting for sheave assemblies.
Lift 10 terminal parts.
Lift 10 contour having the wheels installed.
Lift 10 terminal parts waiting for tires.
Wind speed gauges.
Drive cabinet for A-basin.
Tower heads, and sheave assemblies waiting to be attached for shipment.
I thought it was interesting to see that Vail had medium buttons on their pedestals. The L-P guys said that it was a special request, along with different catwalks on the towers. Does anyone know if they have medium buttons on the other Poma's? I know they had the catwalks put in on the towers on the older Poma's, but I'm not sure about the Medium buttons. Did they just do that so the Lifty's won't have to learn a different system, or is there another reason?
The new E-Stop guards and orange signal buttons are standard, from what I understand. Does anyone know why signal became orange?
Here's some more:
Wind speed gauges.
lastchair_44
17 Aug 2007
Isn't it in the code that the buttons have to be different colors now?
Peter
17 Aug 2007
Lift Kid, did they say what lift it is for Snowmass? I thought they were only installing a fg quad this summer.
Lift Kid
18 Aug 2007
Oops.
That was an error. I meant the lift for Steamboat. I believe it was a 30 tire, per acceleration and deceleration sides.
Stats:
Christie Peak Express
800 HP Omega 6 Place
Detachable Chair
Stats:
Detachable Chair
spunkyskier02
25 Aug 2007
gore's new triple looks like it is coming along nicely.
This post has been edited by spunkyskier02: 25 August 2007 - 07:25 AM
Peter
26 Aug 2007
That lift looks like a Partek? I wonder if it is new or not? I can't see why D-CTEC would still be making Partek designs?
Anyways, here are some pictures I found of A-Basin:
More new pictures online:
http://www.brundage....nstruction.aspx
http://www.skibaldy.blogspot.com/
http://www.timberlinelodge.com/current_new...007_newlift.php
http://www.squaw.com...-express-update
30 Aug 2007
Out with the old... (in with the new next week, if all goes well)
Number of downloads: 42 -
Number of downloads: 34 -
Number of downloads: 24 -
Number of downloads: 33 -
