New lift construction photos
415 replies to this topic
#261 Peter
Posted 07 October 2006 - 10:24 PM
Is it just me or do these windows look different than on other L-P terminals?
#262 SkiBachelor
Posted 07 October 2006 - 10:44 PM
Yep, there are now more windows spaced closer together compared to former Omega terminals.
I think Leitner was doing this with some of its terminals over in Europe too. I presume the reason why is because there is less strain on the windows which prevents them from cracking when there is a lot of weight on them from snow and ice.
#263 Lift Kid
Posted 08 October 2006 - 06:41 AM
Here's more at Buck Hill!
#264 skier2
  • 496 Posts:
Posted 08 October 2006 - 07:22 AM
I've been following the Buck project too. I was there yesterday, and the cable was spliced and running, they were putting on the cable monitors, and they were getting ready to hang the chairs. Also, they had finished with the dirt in the terrain park and were planting trees and rolling out grass seed bales off of the backside above the road for the watertower.
This post has been edited by skier2: 08 October 2006 - 07:23 AM
#265 Lift Kid
Posted 08 October 2006 - 11:03 AM
They have done a pretty good job this year at Buck. Did you happen to see what happened with the old Hall double?
#266 Peter
Posted 08 October 2006 - 01:03 PM
East Ridge Chair and More Lift Capacity This winter skiers and riders will be able to access Rendezvous Bowl, Corbet's Couloir and the backcountry gates via the Bridger Gondola and a series of chairlifts including the new East Ridge Chair.
The East Ridge Chair will rise 600 vertical feet from the top of the Sublette Chairlift to just below Corbet's Cabin. This temporary double chairlift will take skiers and snowboarders up Rendezvous Bowl this winter and until a permanent tram replacement lift is installed.
In addition to construction of the East Ridge Chair, JHMR is adding capacity to the Bridger Gondola and Thunder Chair to ensure seamless mountain access next winter. The Bridger Gondola will have 18 more cabins and Thunder Chair will have 16 more chairs added. From the base, the Gondola will now offer an uphill capacity of 2400 skiers per hour (vs. 1800 previously) - this increase alone will be double the uphill capacity per hour of the tram!
From Jacksonhole.com
#267 SkiBachelor
Posted 08 October 2006 - 01:23 PM
I wonder if the East Ridge chair will replace the Eagle's Nest lift after it's removed?
#268 Peter
Posted 08 October 2006 - 02:05 PM
I think it is slated to be installed to the ridge above the Gondola, pending Forest Service Approval.
#269 Peter
Posted 09 October 2006 - 04:55 PM
New photos of Breckenridge Gondola Tower Construction: http://www.mountainresortmag.com/coppermin...ls.php?album=20
#270 skierdude9450
Posted 12 October 2006 - 05:10 PM
Wow! :shocking: I don't think I've ever seen an 8t/8d assembly before. There must be quite a big span there.
I didn't realize that Jackson Hole got covered in that much snow. That's 8 feet up there.
#271 Peter
Posted 13 October 2006 - 10:08 PM
Peruvian Express at Snowbird, the vault drive top terminal is done.
http://www.snowbird....n/peruvian.html
#272 Lift Kid
Posted 14 October 2006 - 06:07 AM
The stations of the Breck Connect are going in as of the 11th!! :cool:
(picture from Breckenridge's website)
Attached File  10.11.2.LG.jpg (82.47K)
I forgot this one! Buck Hill has the chairs on the line and is currently doing tests! :biggrin:
(this pic is from Buck's website)
Attached File  dirt23l.jpg (76.74K)
This post has been edited by Lift Kid: 14 October 2006 - 06:08 AM
#273 skier2
  • 496 Posts:
Posted 14 October 2006 - 09:21 PM
Yep! The Hall double is in the graveyard/maintenance lot if you go behind the top of the halfpipe-there is a service road that comes off of the access road from the south that also leads to it, or if you climb down to the road that goes to the water tower and walk down, you'll literally run right into half of the parts of the double. It is planned to be reinstalled in the beginner area:( It's a piece of crap and needs to be trashed!
#274 Lift Kid
Posted 15 October 2006 - 05:39 AM
Yea, that thing is a serious peice of crap. It is so rusty that it never quite seemed to look operational. It is also the loudest lift at Buck. Couldn't they gut the electric drive and controls because they were upgraded by Doppelmayr in 2003. Then try to find a used double chair. I think the cost would probably be close to reinstalling and fixing up the old Hall double.
#275 Lift Kid
Posted 20 October 2006 - 06:01 AM
More on the Buck Hill project.
#276 Lift Kid
Posted 20 October 2006 - 01:45 PM
Gondola cars are starting to arive at Breckenridge! They look like POMA cars instead of CWA but I'm not sure.
#277 SkiBachelor
Posted 20 October 2006 - 02:14 PM
Those are CWA cabins.
#278 Lift Kid
Posted 20 October 2006 - 03:47 PM
Ok. I was just making sure.
#279 skierdude9450
Posted 22 October 2006 - 05:29 PM
Those are a cool!
#280 Peter
Posted 22 October 2006 - 09:32 PM
Peruvian at Snowbird
This post has been edited by Skier: 22 October 2006 - 09:32 PM
