Possible new lifts for Summer 2006
#124
Posted 01 April 2006 - 08:32 AM
#125
Posted 01 April 2006 - 07:28 PM
Aussierob, on Mar 31 2006, 08:53 AM, said:
As vons mentioned, B and E were new in '98 and were the last big lifts we built. It does seem like forever ago, doesn't it? We've had several carpets since then, I guess. Which ones were new at Whistler in '99, Fitzsimmons and Garbanzo?
#127
Posted 02 April 2006 - 10:13 PM
maybe something that adds some new terrain?
and whats this on their website that calls for future lifts in the piccolo/flute region, where are those going to go? i thought they were trying to keep flute an "inbounds backcountry". and whats beyond flute for that matter? more bowls?
#128
Posted 03 April 2006 - 04:31 AM
#129
Posted 03 April 2006 - 05:44 AM
Kicking Horse, on Mar 31 2006, 07:40 PM, said:
don't count on it, zep and timberline both will be replaced w/ 6 packs, but not for this upcoming season. this season will see the reinstallation of the outrigger chair on the backside of parsenn and it will run parallel to hi-lo. they're also planning on opening a gate to first creek on the backside en route to the cirque.
the following season will see zep & timberline get replaced w/ 6 packs and most likely moving zep to sunnyside if there isn't enough $$ to buy a new detach to replace sunnyside. sunnyside will be split apart and be used to replace the arrow chair and the looking glass chair.
also, it looks like iron horse will be kept, original plans called for it to be removed at the end of this season, but with the lines we had for SG this past season, Iron Horse has proved that it is still needed.
#130
Posted 03 April 2006 - 07:43 AM
Outrigger will run parallel to Hi-Lo? Will that be from the bottom of the Cirque up to the top of Timberline?
#131
Posted 03 April 2006 - 12:53 PM
Aussierob, on Apr 3 2006, 06:31 AM, said:
yeah, with all the backcountry accessible in that area, it is kind of useless to have a tiny chunk of "inbounds backcountry". im stoked to ride that area though. i love the picture on whistler's homepage, that triple set of bowls in a row could pass as a ski area in itself elsewhere. there its just a tiny portion on the backside of the mountain. wb rules.
what about the peak to creek area? that a pretty hearty swath of trees through there, it would be a shame to see it get cut for trails. and doesnt kyhber go through there? the only time i was in whistler i asked around and nobody i asked even seemed to know what it is. and whats on the backside below that green run, what is it, highway 86? does that just go to nowhere or is there good access out?
#132
Posted 03 April 2006 - 03:30 PM
#133
Posted 04 April 2006 - 06:16 AM
the planned installation is to go from the bottom of the cirque to the top of backside parsenn, no quite to the top of timberline. The primrose trail is on one side of the ridge, the top of the moved outrigger chair will be on the other side of the ridge.
this trail map would give you an idea if you were to draw a line parallel to hi-lo w/ the top of the lift taking you to the top of backside parsenn:
trailmap
#134
Posted 04 April 2006 - 06:41 PM
Snow Valley has so many chairs that no longer operate (#4, #5, #8, #10). Chairs #2 and #9 rarely run either. In 03/04 and this year they make you hike back to Slide Peak to ride Chair 11 since they won't run #9. They did run it in 04/05. I don't go there for this very reason, yet I like Snow Valley more than Snow Summit and Mountain High.
Eric
#135
Posted 05 April 2006 - 10:14 AM
That triple set of bowls IS bigger than most ski areas. In the peak to creek area there is a long term plan for another access lift out of creekside with one or two more lifts above it in the Bagel bowl area. I don't know if more runs would be cut in the trees you mention. As for Khyber, That is out of bounds and has great skiing on big snow days, but there are some cliffs you need to watch out for. Do not go down the backside of whistler as you will be in for a long walk out.
#136
Posted 07 April 2006 - 07:19 AM
#137
Posted 07 April 2006 - 11:19 AM
My guess is that Tombstone will be going to Steamboat to replace the Sunshine lift since Steamboat has been wanting to instatll a HSQ in that area for quite some time.
#138
Posted 07 April 2006 - 11:47 AM
That triple needs replacing. I mean, it's not the bad of a ride. Except that it is a long lift (200+ chairs) and that it often stops or runs slow for beginners and intermediates loading and falling
Drugs Are Bad... Kill a Hippie
#139
Posted 07 April 2006 - 12:48 PM
-Moving Raptor, a 90s CTEC fixed quad, to the Dreamscape line, leaving a 1965 Riblet double to pick up the slack
-Shortening Red Hawk, moving it to a completely different line altogether, converting it from a quad to a double, and renaming it Sunrise. And they don't even run it
-Renaming the high-quality Snow Canyon quad 'Sun Peaks Express'
-Renaming Lookout triple, which I think came from Steamboat, to 'Short Cut'
It wouldn't be complete without a new name to go along. Now the Flight of the Canyons gondola is the only Poma left in Utah
