Random Lift Pictures Number Two
SkiBachelor
29 Feb 2004
Ryan, I presume those angles are right angles? I was just wondering because you have the end points circle and I'm just uses to seeing them with a 'box' where the two lines meet which indicates a right angle, thanks.
Kelly
29 Feb 2004
Small circle is the pivot point for the main axel for this style of assembly. The assembly has a flat spot in this area approximately the size of a 6 pack. 2 - 45's is pretty close. The most important aspect of the drawing is that if the hold down assembly has a pronounced movement the bullwheel alignment turns to cheese whiz!
Image shows 8 wheel hold down at portal and another hold down that is directly uphill. Uphill assembly is on a adjustable tower rather than floating.
WBSKI
13 Jun 2005
Bill, did you used to actually have pages for BC resorts with pictures? It would be so great if you got them up again! :D
SkiBachelor
13 Jun 2005
Yea, there used to be a section and it will be coming back hopefully in the near future. It's just so damn boring to make the lift pages these days for the resorts that I have already done so I've been putting it off.
WBSKI
13 Jun 2005
Great! I see what you mean. Dont you have a copy of the old site on your computer?
