Random Lift Pictures Number Two
145 replies to this topic
#141 SkiBachelor
Posted 29 February 2004 - 03:10 PM
Ryan, I presume those angles are right angles? I was just wondering because you have the end points circle and I'm just uses to seeing them with a 'box' where the two lines meet which indicates a right angle, thanks.
#142 Kelly
  • 3,106 Posts:
Posted 29 February 2004 - 03:32 PM
Small circle is the pivot point for the main axel for this style of assembly. The assembly has a flat spot in this area approximately the size of a 6 pack. 2 - 45's is pretty close. The most important aspect of the drawing is that if the hold down assembly has a pronounced movement the bullwheel alignment turns to cheese whiz!
Image shows 8 wheel hold down at portal and another hold down that is directly uphill. Uphill assembly is on a adjustable tower rather than floating.
www.ropetech.org
#143 WBSKI
    Whistler Skiier
  • 1,164 Posts:
Posted 13 June 2005 - 05:33 PM
Bill, did you used to actually have pages for BC resorts with pictures? It would be so great if you got them up again! :D
#144 SkiBachelor
Posted 13 June 2005 - 05:39 PM
Yea, there used to be a section and it will be coming back hopefully in the near future. It's just so damn boring to make the lift pages these days for the resorts that I have already done so I've been putting it off.
#145 WBSKI
    Whistler Skiier
  • 1,164 Posts:
Posted 13 June 2005 - 06:39 PM
Great! I see what you mean. Dont you have a copy of the old site on your computer?
#146 SkiBachelor
Posted 13 June 2005 - 06:52 PM
Yea I do.
