Super Bee @ Copper
#22
Posted 05 April 2005 - 06:28 AM
#23
Posted 05 April 2005 - 04:46 PM
#25
Posted 05 April 2005 - 05:33 PM
liftmech, on Apr 5 2005, 08:28 AM, said:
Hey thanks for working so hard on that lift. Its guys like you that make Copper one of my favorite areas to play at!
#26
Posted 05 April 2005 - 06:12 PM
As promised, photos. 1) Slopes was quite helpful in providing a cat and operator to drag the motor up to the top. 2) Not a lot of room to back the war wagon in. 3) A rigging rat's nest.
Number of downloads: 53 -
Number of downloads: 49 -
#27
Posted 05 April 2005 - 06:17 PM
Number of downloads: 30 -
Number of downloads: 35 -
#28
Posted 05 April 2005 - 06:30 PM
Number of downloads: 37 -
Number of downloads: 32 -
#29
Posted 05 April 2005 - 06:34 PM
1) Install driveshaft (yours truly pictured, Luke was on the other end because the thing is heavy and takes two people. 2) Install blower motor and filter housing and away she goes!
#30
Posted 06 April 2005 - 01:11 PM
#36
Posted 08 April 2005 - 03:15 AM
We got pictures back from the repair shop; the failure was caused by an insulation failure. A little background on how a DC motor works in in order for this. There are dozens of coils in the armature, which is the rotating part of the motor. The get their power from the commutator, which is a smooth copper drum made up of twice number of copper bars as there are coils in the armature. Each coil is connected to two bars. The bars are insulated from each other and from the shaft they are mounted on. Carbon brushes are pressed by springs against the surface of the commutator, and transmit the current from the drive to the comm. On our motor, the insulating 'doughnut' that keeps current from reaching the shaft failed, causing 480 VDC at whatever amperage the drive was pulling (probably around 300-400 amps) to go straight to ground via the motor shaft. There was a nice-sized hole in the comm.
#38
Posted 08 April 2005 - 09:01 AM
#39
Posted 08 April 2005 - 10:24 AM
#40
Posted 08 April 2005 - 10:41 AM
liftmech, on Apr 8 2005, 04:15 AM, said:
just going by what is on skilifts.org for the SuperBee.
