Posted 31 March 2005 - 12:44 PM
Posted 31 March 2005 - 01:39 PM
Posted 01 April 2005 - 05:00 AM
Posted 01 April 2005 - 05:04 AM
Mike, on Mar 31 2005, 02:39 PM, said:
Top drive lifts have less tension overall because the tension on the bullwheel is always higher at the top terminal. At one point I remember hearing that R-lift ('82 Yan triple, bottom drive) had upwards of 75,000 pounds of tension at the bottom. It has closer to 40,000 now (75 was deemed excessive so a new counterweight was cast several years ago). Our detachable quads, all top drives, also have around 40,000 punds at the bottom even though they're much bigger lifts.
Posted 04 April 2005 - 03:29 PM
Posted 05 April 2005 - 04:54 PM
Posted 05 April 2005 - 05:20 PM
highspeedquad, on Apr 5 2005, 07:54 PM, said:
Then you have not been around to many lifts that are / were running off a diesel or a gas engine.
Posted 06 April 2005 - 09:41 AM
#14
Posted 06 April 2005 - 05:23 PM
Posted 13 September 2006 - 06:32 AM
This post has been edited by garthd: 13 September 2006 - 06:32 AM
#17
Posted 13 September 2006 - 07:34 AM
It may also be for the need where there is space for it. I have seen a few instances in older Yan lifts that the tension block is out in the woods somewhere and is connected to the lifts through cables in order to minimize the amount of space the terminal takes up. I'm not sure about all this, but this is what I have always pictured for tension issues.
Posted 13 September 2006 - 12:43 PM
Posted 13 September 2006 - 04:16 PM
garthd, on Sep 13 2006, 07:32 AM, said:
Dead right on the top tension having to overcome rope weight. Bottom tension top drive is the best, given you have better rope traction on the drive (rope weight), you can get away with a smaller drive if it is a top drive. (I think we've all buried power lines in solid rock)
Posted 13 September 2006 - 04:57 PM
Weight of haulrope is actually needed for bullwheel liner traction if the lift is a top drive.
Bottom terminal tension or counterweights can be somewhat smaller when comparing similar systems – however when using hydraulic tension this is immaterial because pressure of the tensioning ram is (somewhat) easily adjusted.
Interaction between number of towers, spacing, speed, size of carrier, and line terrain also play important parts…so we return to design and utility location.
