Lift Engineering (Yan)
#42
Posted 24 March 2005 - 06:12 AM
Duck, on Mar 23 2005, 06:33 PM, said:
-Iain
You don't. It is the job of the splicer to make the tucks as close to the original rope diameter as possible, so that a grip can close on them. Grips are designed to close on a 'nominal' rope diameter, but that means there are variations inherent and accepted. There is a window around nominal diameter in which grip force is unchanged.
#44
Posted 25 March 2005 - 03:49 PM
SkiBachelor, on Mar 22 2005, 06:06 PM, said:
Several of the structural framing components, monopods and quite a few towers were re-used in the Poma installation at Squaw.
Welded on both projects.
#45
Posted 25 March 2005 - 04:03 PM
there is some talk about relocating the current gondola at river run. does anyone know if they will scrap the von roll system and install a new one?
#46
Posted 25 March 2005 - 04:05 PM
Do you know where they would relocate it to?
#47
Posted 25 March 2005 - 04:10 PM
#48
Posted 25 March 2005 - 06:51 PM
#49
Posted 26 March 2005 - 05:12 PM
Elevation 9,600 Feet
President
#50
Posted 26 March 2005 - 05:16 PM
crazyskier91, on Mar 26 2005, 07:12 PM, said:
What did they upgrade?
#52
Posted 27 March 2005 - 11:13 AM
As Bud mentioned on page 2 it had an active spacing and conveying system.
-Lift was under construction until it was removed
-Short conveying chains at turns coupled with tires at that transition - I believe were rope driven
-Groups of tire “banks” for spacing correction and acceleration/deceleration
-Still needed motors, shafts and couplings to drive system
-Active system used higher than “control voltage” electric motors, as one can imagine this created slight problems during power outages as the tires did not turn.
-All tires in banks were commonly connected by V-belts
-Belt tension was adjusted by sliding the tire assembly(s) down a common pipe rail for belt stretch.
-These pipe rails were parallel to the slope of the haul rope – an elegant and simple design for correct traction plate contact and belt alignment … in theory.
-No tension pulleys for V-belt slack - move one to tighten – move all - job security for maintenance for proper belt tension. To change or replace a belt one had to be creative.
As with most spacing systems the active system was pretty benign/ hard to tell at 100% rope speed.
As Bud implies - bit of a white elephant.
#53
Posted 17 November 2006 - 06:58 AM
Why such interest in what has become ancient history?
I'd like it if these interested guests sign on as members so they can post an answer to this question. You know, as a non-member, you really miss a lot.
#54
Posted 17 November 2006 - 06:47 PM
Posted 17 November 2006 - 06:51 PM
Skier, on Nov 17 2006, 09:47 PM, said:
#56
Posted 17 November 2006 - 07:38 PM
This post has been edited by Emax: 17 November 2006 - 07:39 PM
#57
Posted 17 November 2006 - 08:39 PM
They are bots for the most part... Ask Bill or Cameron about what I mean.
#58
Posted 17 November 2006 - 08:43 PM
Yes - I know what you mean. But why here?
#60
Posted 17 November 2006 - 09:05 PM
However, we forgot to submit this domain to Google when we moved the forum to its very own site and therefore you can no longer find any threads from the forum on Google anymore. However, I did submit it today and hopefully the bots will be back scouring the site in the near future. It will take some time to though to get the #1 position that we once had.
