Lift Engineering (Yan)
#25
Posted 30 July 2004 - 07:03 AM
Powdr
#26
Posted 22 March 2005 - 03:32 PM
Some of the cabins from the original keystone gondola can still be found arround summit county as some people purchaced them when it was removed.
#27
Posted 22 March 2005 - 04:57 PM
This post has been edited by poloxskier: 22 March 2005 - 04:59 PM
#28
Posted 22 March 2005 - 05:17 PM
Kinda scary! I also remember that when I worked at the local Boy Scout ranch in the summer, one of my co-workers was the top liftie when it fell. He was pretty upset when it happened and would not talk about it even years later. Now if I could only remember his name.
This post has been edited by caroth: 22 March 2005 - 05:20 PM
#29
Posted 22 March 2005 - 06:06 PM
Do you happen to know why Keystone's YAN gondola was removed also. I talked with one of the lift mechanics there and he believed that they removed it since they didn't like how the grips started to appear after a certain amount of time. However, if they were Von Roll grips along with the terminals, I don't see how that would be YAN's fault. That's why I'm curious.
If Alex Cushing and Keystone didn't like the cabins, why didn't they just go out and purchase CWA cabins instead, because I could see how it would get kind of annoying having to manually opne those cabin doors all the time.
It's also kind of interesting that the YAN gondola towers were also removed when they could have easily been reused.
#30
Posted 22 March 2005 - 06:20 PM
This post has been edited by poloxskier: 22 March 2005 - 06:21 PM
#32
Posted 22 March 2005 - 06:26 PM
#33
Posted 22 March 2005 - 06:41 PM
http://www.skilifts.org/nwsforum/index.php...c=1288&hl=cabin
This gondola cabin is located right next to the Summit Express at keystone at the small cabin that you can see next to the lift. If you go to Keystone in the summer, you can easily spot it.
#34
Posted 22 March 2005 - 06:45 PM
Its been a while ago that I rode that for obvious reasons but I remember it being a really nice and comfortable gondola from a skier standpoint. But like the River Run before they either removed some of the cabins or worked out the bugs the cabins did colide in the terminal.
This post has been edited by poloxskier: 22 March 2005 - 06:52 PM
#35
Posted 23 March 2005 - 08:22 AM
That also makes me wonder why, if it was the Von Roll grips that they didnt like about the Yan gondola, that they then bought a gondola from Von Roll. Also It does suprise me that there were no towers reused, although the first depression does look different from most Von Roll's that I have seen.
#36
Posted 23 March 2005 - 09:27 AM
budfischer, on Mar 22 2005, 08:31 PM, said:
Sounds a lot easier to me than the current method of using a lot of tires and belts with tons of moving parts. :) Were the drive motors driven off a VFD? If so, that's pretty simple to do (just set the ramp in the drive, give it a start/stop signal, etc). I'm interested to learn what the exact mechanical design of the chain/sled/conveyor was, and how it'd smoothly engage the carrier on arrival at the terminal.
What do you mean by "hard wired PLC"? Do you just mean it was relay-logic driven with a whole bunch of proximity or limit switches?
-Iain
#37
Posted 23 March 2005 - 11:59 AM
budfischer, on Mar 23 2005, 10:22 AM, said:
So was the grip that was used similar to the type 7 or was it a specific gondola design?
#38
Posted 23 March 2005 - 01:06 PM
#39
Posted 23 March 2005 - 05:33 PM
budfischer, on Mar 23 2005, 01:55 PM, said:
Sure, that makes sense. To reduce the wear on the grip, right? (learned about that here!)
So I'm visualising this, based on your description, as a loop of rope, with a sled/skate on it which couples somehow to the carrier as it enters the terminal? That must have sounded pretty neat, with it ramping up/down every time a cabin came in or left!
budfischer said:
Now that sounds very difficult! I wonder why on that particular system, it was unsafe to grip where the main rope was attached together. How would you get around that on a conventional tire-driven detachable?
-Iain
#40
Posted 23 March 2005 - 07:09 PM
The two rollers parallel with the haulrope guided the cabin in its detached state. Third arm was for door activation. Slots in the floor guided both. Clean simple design with only slight problems with slot icing in heavy snow. Hell to get open in an evacuation if you didn’t have the right tool.
Slots in floor were difficult to place prior to the pouring of concrete, repairs and changes often looked like a Los Angeles freeway interchange.
