Tire vs. chain driven turn-arrounds
Posted 06 March 2005 - 10:37 AM
Also does anyone know the first lift in the world, and North America the used only tires in the terminals?
Posted 06 March 2005 - 11:24 AM
Posted 06 March 2005 - 06:58 PM
Chains are definitely way easier if you hve a problem. Usually a quick call to the lifty to tell thm to put one chair in each set of teeth does the trick. Tyres are fine as long as you look after tyre pressure and belt tension. However if you stall a chair or two or three it will be time consuming to fix. I think the reason tyres are used almost exclusively is that the system is simpler and more compact and requires less horsepower to drive. One more note about spacing chains, if you break it, it will be a nightmare.
Posted 06 March 2005 - 07:07 PM
Posted 06 March 2005 - 08:35 PM
KZ, on Mar 6 2005, 10:18 PM, said:
Thats what I was thinking and what made me ask the question.
Posted 07 March 2005 - 06:52 AM
Boy there is a lot of Poma guys on ths forum. All this talk of cadencing. Doppelmayrs space instead of cadence. :P [/quote]
This is true. You may be the token Doppeldude :P
[right]<{POST_SNAPBACK}>[/right]
[/quote]
This is also true. We had a broken link on the Flyer's cadence (spacing :D) chain last week, and when it jammed in the guide rail it caused the transmission ghain to bind. While it didn't break, they had to break it to move the cadence chain out of the guidage to fix the broken link. 49 minutes down. Not fun.
Personal opinion: chains = more maintenance but simpler spacing. As Aussierob said, they're very easy to explain to lift operators. Tyres = less hardware and maintenance, but more issues when the spacing clutch goes out or when chairs stall. From a bean-counter's standpoint, tyres make more sense as there are much less maintenance costs involved.
Posted 07 March 2005 - 09:12 PM
highspeedquad, on Mar 6 2005, 07:07 PM, said:
But if you do have a clutch shaft break, you can still run the lift...just without spacing. And you are still able to core space if you start having spacing issues.
A little off topic, but AussieRob, is Nells still working for you guys?
Posted 07 March 2005 - 10:00 PM
Posted 07 March 2005 - 11:31 PM
No you can't just have a ops person there to space. Doppelmayr spacing works 2 ways Fine spacing (uses a high and low clutch to speed up or slow the chair down in the curve) These clutches are found in the drive station or Coarse spacing (Uses clutches to stall or stow chairs(can have up to 5 chairs in the station at one time 3 in stow, 1 entering, 1 exiting) and automatically spits them out according to preset spacing values(impulses) Coarse spacing is done at the return.
Posted 08 March 2005 - 08:58 AM
Posted 08 March 2005 - 02:59 PM
Posted 08 March 2005 - 05:14 PM
Elevation 9,600 Feet
President
Posted 08 March 2005 - 05:47 PM
This post has been edited by highspeedquad: 08 March 2005 - 05:47 PM
