Ridge Chair
17 replies to this topic
#1 WBSKI
    Whistler Skiier
  • 1,164 Posts:
Posted 29 January 2005 - 07:03 PM
I read some where about a lift called the Ridge Chair on mount seymour that got damaged in 1998. Does anyone know anything about this lift?
#2 SkiBachelor
Posted 29 January 2005 - 07:50 PM
Where are you Vancouverguy?
Anyway, I believe it was struck by lightening and Seymour didn't have the funds to fix it or didn't feel like it was worth it to fix the lift up.
Well here are some pictures that Vancouverguy took about 2 years ago I think. He once was a pretty active member on the forum until he disapeared all of a sudden without saying anything. :huh:
Attached File  lifeline.jpg (230.53K)
Number of downloads: 49Attached File  topterminal.jpg (179.37K)
Number of downloads: 34Attached File  topterminal2.jpg (285K)
Number of downloads: 53nt]
Attached File  towersheave.jpg (135.54K)
#3 WBSKI
    Whistler Skiier
  • 1,164 Posts:
Posted 29 January 2005 - 08:02 PM
Thanks for the pics, do you know where the lift ran from and to?
#4 SkiBachelor
Posted 29 January 2005 - 08:26 PM
Here is a trail map of the area. The Ridge chair is the area that has all the red lines going through it and says "area temporary closed."
http://skimaps.com/map2535
#5 Whistler
  • 369 Posts:
  • Interests:snowboarding, skiing, swimming, school....just kidding, skateboardin etc etc.
Posted 29 January 2005 - 08:51 PM
WBSKI, have you skied at Mount Seymour before? if so, it is located to the right of the rental shop, about a two minute walk. It's actually quite neat to check out, I climbed inside the terminal once, and it's a pretty neat site to see. The lift itself was quite short, I actually walked down to the bottom of it once, although the operator house and all the controls have been removed.
#6 WBSKI
    Whistler Skiier
  • 1,164 Posts:
Posted 29 January 2005 - 09:06 PM
Yes I have skiied there once before and so I know what you are talking about. I emailed Mt Seymour a while back about chairlift E but just said it was closed undefinitely
#7 liftmech
Posted 30 January 2005 - 04:44 AM
Cam, the lift maintenance supervisor there, came by Baker a few years ago and I showed him around our Chair 4. We were about to take it down (this was the spring of '02) and he wanted to see what shape it was in for parts. He wanted to rebuild the Ridge lift but as Cameron mentioned he didn't have a lot of funds. He did end up hauling up several pickup truck loads of parts, but he could have put them on the Brockton or the Mystery Peak lifts as well, I never heard.
#8 WBSKI
    Whistler Skiier
  • 1,164 Posts:
Posted 27 February 2005 - 07:34 PM
Does anyone know if there used to be a short lift on the other side of the parking lot, theres a cut area over there.
#9 SkiBachelor
Posted 27 February 2005 - 07:35 PM
Check it out on Topozone.com or a site that has topo maps for Canada. I'm sure you will be able to dig something up if the lift is old enough.
#10 poloxskier
  • 1,626 Posts:
Posted 27 February 2005 - 07:46 PM
What is the make of the ridge chair?
#11 liftmech
Posted 27 February 2005 - 09:48 PM
Murray-Latta.
#12 WBSKI
    Whistler Skiier
  • 1,164 Posts:
Posted 01 March 2005 - 04:00 PM
I believe topo zone only has US maps, I cant find any canadian ones
#13 WBSKI
    Whistler Skiier
  • 1,164 Posts:
Posted 25 March 2005 - 10:20 PM
I went up Seymour today on a hike, a great way to get to the bottom of the Ridge Chair I found was to drive to the Group Campground, then take a trail that runs from the other side of the road down there until you cross a bridge with a couple holes in it and then head up the hill into the bush and not far up you will get to the ski run, (its getting quite overgrown), then cross a half dried up creek, walk along a little open parralleling the dried up stream, cross the stream again just before there is a couple logs piled up, they are slippery, walk to the chairlift, this is just one way to get to the lift, all this is fairly close together so there are multiple possible routes.
Now for the pictures!
#14 Whistler
  • 369 Posts:
Posted 25 March 2005 - 10:25 PM
As always, great pics! Poor old lift looks like it's in pretty rough shape. When did it stop running? It had to have been quite a while ago now because there is no safety bars on the chairs, and that rule to have them has been in place for quite some time now...
#15 WBSKI
    Whistler Skiier
  • 1,164 Posts:
Posted 25 March 2005 - 10:37 PM
Yes, I should have taken pictures of the front side of the top building, the roof is sagging in! I believe the lift stoped around 1998?? Yes, safety bars, one more thing to add if they started the lift again, dont think they will though. It is quite a ways away from the other lifts, Seymour is bad that way, you have to walk to the other lifts. There used to be a ropetow farther down (Enquist) Where the tubing area is now, the tubing lift doesnt run all the way to the bottom of the runs for enquist.
#16 liftmech
Posted 27 March 2005 - 04:34 AM
When did the tubing lift go in? I last skiied Seymour in April of 2002 and I don't remember it.
#17 big air
  • 11 Posts:
Posted 27 March 2005 - 09:53 AM
Those pictures are depressing. It used to provide the best skiing on the hill. It was well lit for night skiing and as kids, we were on it all the time. Too bad they can't or won't fix it.
#18 WBSKI
    Whistler Skiier
  • 1,164 Posts:
Posted 27 March 2005 - 11:07 AM
Yes, it is a shame, I never went on it, it looks good though. The tubing lift is quite aways away from the downhill area now that Ridge Chair is closed, you might not have seen it when you were there.
