First High Speed lift you rode on
#21
Posted 03 February 2005 - 10:22 AM
BTW my first chair lift ride was the 1959 Riblet Double at the Broadmoor and my first surface lift was the handle tow at the Broadmoor.
#23
Posted 03 February 2005 - 11:49 AM
#24
Posted 03 February 2005 - 12:00 PM
Breck should just buy some more carriers for the Quicksilver if the lines are always bad.
#25
Posted 03 February 2005 - 12:06 PM
#26
Posted 03 February 2005 - 12:32 PM
Part of the most fun was discovering cadencing. After watching and thinking about things for a while I decided chair spacing was a requirement and thought it probably occured in the curve somewhere via a separate drive... I was pretty happy to find out online afterword that's pretty much exactly what happens!
-Iain
#30
Posted 03 February 2005 - 03:29 PM
It opened for the 1984 ski season (which is June-September), so I guess it was pretty early in the detachable game. I do know that it has grips that don't look like any other Doppelmayr grips I've seen (Buller has a newer HSQ, and I've seen several others in Vail).
I remember just being in total awe of the Blue Bullets at Buller when I was a kid .. the terminals had wheels, ropes, rods and belts seemingly going in every direction.
Buller has (well had) some interesting lifts. There were two (parallel) detachable poma (platter) surface lifts, which both had what I'd guess to be a 30 or 40 degree turn half way up. I wish I had pictures of that.. Sadly they have been removed. They also had a double sided poma (you load at both ends, and get off in the middle), part of that poma actually remains (probably more sentimental value than anything!).
Buller also has a Doppelmayr high-speed-quad as an access lift from one of the car-parks. This lift has an interesting mid-loading station, where the carriers do not detach. The sheave train is attached to the tower in such a way that it can be raised/lowered. When the mid-loading station isn't used, the sheaves (and thus the haul-rope) is raised in the air and the lift runs at full speed. In order to use the mid-loading station they lower the sheaves (which lowers the rope and carriers), and slow the entire lift down. I've only watched the transition once, and it takes several minutes (with the chair stopped) for it to whole thing to take place. If they use the mid-load station, it's usually for most of the mid-day .. then they revert to high-speed running late in the day (to get the skiers off the mountain).
Cameron.
ps: Great site, by the way. I'm a pinball geek, coaster geek, and now a ski-lift geek too!
[Edit to fix typo]
This post has been edited by Cameron: 03 February 2005 - 03:32 PM
(No, I'm not the same Cameron who knows everything about ski-lifts!)
#32
Posted 03 February 2005 - 04:11 PM
Is this the style that they had on their quads?
This post has been edited by poloxskier: 03 February 2005 - 04:15 PM
#33
Posted 04 February 2005 - 10:07 AM
I will be back in Melbourne in early April for two weeks, and I'll see if I can get up there to take some photos. Although it will still be over 6 weeks to the start of the ski-season, so I don't know if the carriers will be on the line yet.
#34
Posted 04 February 2005 - 10:18 AM
This post has been edited by poloxskier: 04 February 2005 - 04:50 PM
#36
Posted 04 February 2005 - 04:48 PM
#37
Posted 04 February 2005 - 04:52 PM
#38
Posted 04 February 2005 - 06:34 PM
Elevation 9,600 Feet
President
#39
Posted 04 February 2005 - 06:38 PM
