Doppelmayr red sheave
12 replies to this topic
#1 keith
  • 1 Posts:
Posted 15 November 2004 - 04:34 AM
What is special about the red sheave in a Doppelmayr sheave set?
#2 liftmech
Posted 15 November 2004 - 05:30 AM
It weighs a ton. Technically, it's called a 'drop sheave', and it is there to make that particular sheave assembly rotate and break a brittle bar in the event of a deropement. Normal Doppelmayr (and Poma, for what it's worth) sheaves are cast aluminum bodies with aluminum flanges. The drop sheave is a steel body with a steel flange, and there are also aluminum-bodied sheave with steel flanges that also serve as drop sheaves. It's all very confusing to a poor Poma monkey like myself, but apparently it makes sense to the Germans.
#3 Allan
Posted 15 November 2004 - 06:17 AM
They are definately heavy!! Even the T-bar ones!! I remember picking one up for the first time, and thinking this little thing shouldn't be this heavy!
#4 tomcse
  • 24 Posts:
Posted 21 November 2004 - 01:57 PM
According to the documentations for our Doppelmayr BP 680 T-bar, the red sheave is 20,2kg and the normal one is 12,5kg heavy...
#5 floridaskier
Posted 21 November 2004 - 04:13 PM
Thats still a lot (like 45 pounds if anyone doesnt feel like doing the math) I didn't think the regulare ones weighed that much, I thought it was more like 5 kg
#6 Allan
Posted 21 November 2004 - 05:07 PM
Something I've learned... almost everything relating to lifts (and snowcats) is surprisingly heavy!
#7 edmontonguy
    Edmontonguy
  • 927 Posts:
Posted 21 November 2004 - 05:50 PM
Just looking at a chair for example you'd think it'd be really nice and easy to lift but it really isn't!
#8 Skidude
  • 88 Posts:
  • Interests:Roller Coasters, Ski Resorts, Waterparks, Arcades, and Computer Games.
Posted 21 November 2004 - 09:48 PM
When I went hiking at Ski Sunrise I found a poma lift stick. I tried to lift it but it took me, my dad, and my brother to get it off the ground.
#9 liftmech
Posted 22 November 2004 - 06:33 AM
Poma sticks are surprisingly heavy, aren't they? We have to swap them out regularly on Storm King, and it takes two of us.
You want a heavy sheave- try Doppelmayr's terminal deflection sheaves. They are 700 mm in diameter and weigh 136 kilos...
#10 floridaskier
Posted 22 November 2004 - 04:17 PM
Pardon my ignorance, but what's a lift stick?
#11 poloxskier
  • 1,626 Posts:
Posted 23 November 2004 - 09:56 AM
I've noticed that some yans have red sheves as well. Are they similar in function to the Dopps?
#12 SkiBachelor
Posted 23 November 2004 - 10:15 AM
Nope, instead they are used to ground out the static electricity that builds up on the haul rope as it accumulates passing over the sheaves. Poma has this same type of set up to I believe.
There is a topic about this somewhere on the forum if your interested in searching for it.
#13 liftmech
Posted 27 November 2004 - 04:50 AM
The skier-towing apparatus on a surface lift such as a platter is called a stick.
