Doppelmayr red sheave
Started by keith, Nov 15 2004 04:34 AM
12 replies to this topic
Posted 15 November 2004 - 05:30 AM
It weighs a ton. Technically, it's called a 'drop sheave', and it is there to make that particular sheave assembly rotate and break a brittle bar in the event of a deropement. Normal Doppelmayr (and Poma, for what it's worth) sheaves are cast aluminum bodies with aluminum flanges. The drop sheave is a steel body with a steel flange, and there are also aluminum-bodied sheave with steel flanges that also serve as drop sheaves. It's all very confusing to a poor Poma monkey like myself, but apparently it makes sense to the Germans.
Posted 21 November 2004 - 01:57 PM
Allan, on Nov 15 2004, 06:17 AM, said:
They are definately heavy!! Even the T-bar ones!! I remember picking one up for the first time, and thinking this little thing shouldn't be this heavy!
According to the documentations for our Doppelmayr BP 680 T-bar, the red sheave is 20,2kg and the normal one is 12,5kg heavy...
Posted 22 November 2004 - 06:33 AM
Poma sticks are surprisingly heavy, aren't they? We have to swap them out regularly on Storm King, and it takes two of us.
You want a heavy sheave- try Doppelmayr's terminal deflection sheaves. They are 700 mm in diameter and weigh 136 kilos...
Posted 23 November 2004 - 09:56 AM
I've noticed that some yans have red sheves as well. Are they similar in function to the Dopps?
Posted 23 November 2004 - 10:15 AM
Nope, instead they are used to ground out the static electricity that builds up on the haul rope as it accumulates passing over the sheaves. Poma has this same type of set up to I believe.
There is a topic about this somewhere on the forum if your interested in searching for it.
#13
Posted 27 November 2004 - 04:50 AM
floridaskier, on Nov 22 2004, 04:17 PM, said:
Pardon my ignorance, but what's a lift stick?
The skier-towing apparatus on a surface lift such as a platter is called a stick.
