1st Hsq In World Found!
Started by coskibum, Nov 08 2003 04:05 PM
71 replies to this topic
#24
Posted 13 November 2003 - 07:10 PM
cuz it's cost some $$$$$$ to put new chairs on. I think that chair had somewhere around 80 to 90 chairs on it when it was @ breck. BTW that was the first chairlift i was ever went on. :) other then the rope tow. but i don't count that as a chairlift
#36
Posted 19 November 2003 - 07:03 PM
poma uses the same caydence chains in their older lifts. vail's doppelmayr hsqs have it too since they are older.
most older gondolas have the push system in the terminals, i know that the phb/hall gondola like you suggested at park city had this. also, if anyone remembers the von roll gondola at disney world it also had this system.
#37
Posted 19 November 2003 - 07:04 PM
The chain system really only carries the carrier (chair) around the countour and then drops it off at the brake rail which then tires which are above accelerates the lift. On top of the grip is a flexible plastic grip . Hope this helps, and welcome to the forum. :)
P.S. The glossary also has some useful info: http://skilifts.org/glossary.htm
The tires that accelerate the lift.
Flexible plastic grip.
