Constam Lifts
crazyskier91's Photo crazyskier91 30 May 2004
All of the websites I have visited have lacked info on Constam lifts. I got bored one day and found this. It has a bit of info on this mysterious brand.
Attached File  us_hof_ernst_constam.pdf (77.5K)
The PDF no longer works please scroll to post # 22 for an extensive history - Admin
liftmech's Photo liftmech 30 May 2004
That's more than I knew before...
I think the old T-bar up at Climax was a Constam. There are or were many of his T-bars in Colorado.
I read about one in North Carolina and there was also one at Pico Vermont.
Dr Frankenstein's Photo Dr Frankenstein 30 May 2004
Constam (I think) T-Bar, Mont St-Sauveur :)
I think that is a Constam, it seems like he used wooden towers a lot, I don't know if anyone else made wooden towers. Anyone know if there are any left operating.
floridaskier's Photo floridaskier 31 May 2004
Wooden towers were used for the first lift at Snow Park Resort, the predecessor to DV in the 40s and 50s. The owners built it themselves though
crazyskier91's Photo crazyskier91 01 Jun 2004
Most lifts if not all with wooden towers have been demolished for obvious reasons.
Dr Frankenstein's Photo Dr Frankenstein 01 Jun 2004
Constam double. Credit: chairlift.org
ODDfreakPERSON's Photo ODDfreakPERSON 01 Jun 2004
not much greater then wood :rolleyes:
well maybe it is...
SkiBachelor's Photo SkiBachelor 01 Jun 2004
The reason why a lot of lifts back in the day used 'wood towers and terminals' was because of the lack of steel from the Korean war.
liftmech's Photo liftmech 01 Jun 2004
That's an interesting photo. You don't see portal towers much anymore, and especially not guyed off like that one is. Now it's all tube steel and massive concrete footings, and only for heavily loaded depression towers.. Also- note the seat/basket is not centred on the stem- I suppose it's for counterweight purposes. That's a little odd to me because it appears that those chairs have a tendency to swing out if left neutral, while most others swing in.
Dr Frankenstein's Photo Dr Frankenstein 02 Jun 2004
Yes it is.
You can also see there's no sheave liner.
Why is there only two sheaves on the loaded side?????
crazyskier91's Photo crazyskier91 02 Jun 2004
Those must be very strong, I know that the old T-Bar at Pico ran single chairs in the summer as a sight seeing ride. What I don't get is why they didn't use the chairs in the winter too, a lot of people must have fallen near the top and that would reduce the times the lift would start and stop.
Dr Frankenstein's Photo Dr Frankenstein 03 Jun 2004
Because T-Bars can run faster.
crazyskier91's Photo crazyskier91 03 Jun 2004
I suppose that does make sense, well I guess i'm not always right but sometimes I think that my thoughts are fact. :evil:
floridaskier's Photo floridaskier 03 Jun 2004
There doesn't seem to be a whole lot of angle change, if any, and it's probably not too heavy. You hardly ever see that now
TRosenbaum's Photo TRosenbaum 11 Jan 2007
That picture of the guyed tower structure looks very similar to the Constam T-bar that used to operate at Cliffs Ridge (now Marquette Mountain in Marquette, MI, USA). The sheaves were not rubber lined. There was quite a jolt and clunk-clunk sound as the T-bar passed over the sheaves. The Tees were horribly leaky things with an oil-damped shock and large external spring. Under certain weather conditions the Tees would freeze up (or require more force to extend) thus providing us with a thrill ride as we (as small children) were lifted several feet into the air for much of the ride (and sometimes spun around backwards).
Warren733's Photo Warren733 18 Jan 2007
The one in NC would have had to have been at the original Cataloochee Ski Area on Fie Top, unlike it is today on Moody Top. They moved to Moody in 1967/1968. It had opened on Fie Top in 1961.
ceo's Photo ceo 22 Jan 2007
Sounds exactly like the five old T-bars Sugarloaf/USA in ME used to have (and that's the same tower design). One had been replaced with the Double Runner chair by the time I started skiing there, and two others upgraded to reel-type Ts (is there an official name for these?). Those old telescopic Ts on the long, slow #5 T-bar would lift up small children even when they weren't frozen up. All are now gone except #3 (Bateau), which provides upper-mountain access on windy days (and has updated sheave trains etc.).
I think Pleasant Mountain (now Shawnee Peak), also in ME, used to have one of those chairlifts. They certainly had an ancient double with guy-stayed portal towers and no safety bar the one time i was there (in 1977). They'd retrofitted it with actual seat belts.
Allan's Photo Allan 22 Jan 2007
 ceo, on Jan 22 2007, 11:36 AM, said:
... and two others upgraded to reel-type Ts (is there an official name for these?).
They're called springboxes. :thumbsup:
