Sheave Train Naming
6 replies to this topic
#1 Conrad
  • 167 Posts:
  • Interests:Skiing, Hockey
Posted 30 April 2017 - 12:21 PM
A friend of a friend of mine is creating a French/English glossary of ropeway terminology and has one question about sheave trains.
Depression tower (or hold down tower)
Support tower
The question is: what is the name for this type of tower?
To me*, this would make sense as being called a "compression" tower. However, I've noticed an older skilifts.org thread where compression is used synonymously with depression/hold down.
*non-lift-expert
Thanks in advance for any help!
Photos from Sherburne at Burke and Jordan Bowl at Sunday River
This post has been edited by Conrad: 30 April 2017 - 05:26 PM
#2 Lift Dinosaur
  • 2,076 Posts:
Posted 30 April 2017 - 02:38 PM
To me a compression assembly is synonymous with hold down / depression.
The assembly in question is called a combination assembly; a support/compression assembly; or by one Manufacturer, a double effect assembly.
#3 Conrad
  • 167 Posts:
Posted 02 May 2017 - 04:57 PM
Thank you very much for the information Dino, and the person with the question says a big thanks as well!
The French word being translated is specific to the tower itself. So would it be appropriate to refer to such a tower as a "combination tower?" Or perhaps "combination assembly tower?" Or is there just not a commonly used phrase specific to these towers?
Many thanks again for the help!
#4 mikest2
    Mountain Operations
  • 1,204 Posts:
Posted 02 May 2017 - 07:37 PM
In Doppelmayr terminology (Doppelspeak) this is a 4T/4D assembly, the T if for Tragrollenbatterie (support) and the D is for Druckrollenbatterie (compression)
So an eight sheave support assembly would be an 8T, and an eight sheave compression assembly would be an 8D
...Mike
#5 Lift Dinosaur
  • 2,076 Posts:
Posted 03 May 2017 - 08:02 AM
Since he is using "Support Tower" and "Depression Tower" I would suggest 'Combination Tower' or 'Support/Compression Tower'.
Also, in keeping with the Doppelspeak when D= Compression, I would change "Depression Tower" to 'Compression Tower'.
JMHO
#6 Kelly
  • 3,105 Posts:
Posted 04 May 2017 - 02:35 PM
As others have suggested...This style is often shortened to the word “combo” … combination assembly.
The original picture shows a spring tensioned assembly, Riblet (in most cases) uses the rubber of the sheaves as a tension device in their combination assemblies.
Spring Combo
Solid Combo
www.ropetech.org
#7 Conrad
  • 167 Posts:
Posted 04 May 2017 - 03:34 PM
Thank you all very much for all the help!
